CEL question - Mustang Evolution
Old 05-20-2011, 10:35 AM   #1
Greg687's Avatar
Region: New Mexico
CEL question
CEL came on and it's the "evaporative purge valve malfunction" one. I also have another symptom that might be related... when I remove the fuel cap I get a LOT of pressure released. So, the vapors that build in the tank are not being burned in the engine. Is it possible that an incorrect gas cap could cause this? Or am I doomed to try to fix the maze of hoses going to the evap canister?
Thanks
Greg
Greg687 is offline   Reply With Quote
Old 05-20-2011, 10:42 AM   #2
Re: CEL question
could be something simple like that not sure, what code number is it giving with the error?
Old 05-20-2011, 10:44 AM   #3
Send a message via Skype™ to Texastboneking
Re: CEL question
no its good that its holding pressure that means your lines are good and not leaking the pressure out and that your evap purge valve is not opening. i say replace the valve and you should be good to go
Texastboneking is offline   Reply With Quote
Old 05-20-2011, 11:01 AM   #4
Greg687's Avatar
Region: New Mexico
Re: CEL question
I didn't write down the code while at Autozone (dumb move). They carry the valve for $50 though it looks like I will have to replace some of the vacuum lines along with it. So, this will allow the tank to vent properly then? I've never had a car blow fumes at me when I took the cap off before
Old 05-20-2011, 11:05 AM   #5
Re: CEL question
yes. and you shouldn't get fumigated anymore lol
Old 05-20-2011, 07:25 PM   #6
Greg687's Avatar
Region: New Mexico
Removed the valve today and jumped the connector. Sounded like it wanted to work but no airflow through it. Cleaned it with darn cleaner and a compressor then jumped it again. Heard the valve open and close and air flows through when open. Cleared the code and reinstalled. Hope that does it. Thanks you all!
Old 05-20-2011, 07:32 PM   #7
Lol that's one way to make it work again lol. Good luck
Old 05-20-2011, 07:43 PM   #8
Greg687's Avatar
Region: New Mexico
Yeah. I am rationing my money so I have some for the fun stuff. $50 for a part I could clean up was money I could use for window tint lol!
Old 05-20-2011, 08:11 PM   #9
Well you got lucky. Usually the solenoid goes bad.
CEL/Problems 05torch 2005-2010 Mustang GT 6 11-15-2009 08:25 PM
cel help saleenman 1996-2004 Mustang GT 4 10-23-2009 10:19 PM
CEL now on... p1520? jimmy_beaner 1996-2004 Mustang GT 7 04-01-2008 02:04 PM
hey I have a CEL that.... Fishers Stang 1996-2004 Mustang GT 11 07-03-2005 11:14 AM
new 02 sensor but still CEL??!! a1yola Pre-2005 V6 Mustang 9 12-06-2003 05:53 AM
03:23 AM
