TLOK NEXT, BUT... - Mustang Evolution
Old 05-31-2011, 09:28 AM   #1
CHILE10_STANG's Avatar
Exclamation TLOK NEXT, BUT...
sooo im gonna get a tlok installed but i dont have enough money for a tlok and gears - ive already spent a lot re-doing my exhaust and what not.
Ford Racing 7.5" 28 Spline Traction - LOK Mustang Limited Slip Differential at AmericanMuscle.com - Free Shipping!
so i want to get this tlok installed, i just want to know whether you guys think its worth doing just a tlok, or does it have to be a tlok and gears?
thanks!
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 05-31-2011, 09:43 AM   #2
DarkShadows's Avatar
Youll get the most bang if you wait and get gears too. You will also have to pay installation twice if you do it separately. Just buy the tloc and hold on to it till you got the money for the gears and install.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 05-31-2011, 09:48 AM   #3
Send a message via Skype™ to Texastboneking
+1 that's what I'd do
Texastboneking is offline   Reply With Quote
Old 05-31-2011, 09:52 AM   #4
shaqfu's Avatar
Re: TLOK NEXT, BUT...
i am hoping to do the same thing, but most everyone mentions the double install fees, so seems like best to do all at one time and get tuner also....
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 05-31-2011, 09:53 AM   #5
Yea, makes more sense... Will i still be able to notice an improvement with just a tlok?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 09:56 AM   #6
No performance gains. Just fry two tires instead of one gain
Old 05-31-2011, 09:56 AM   #7
FOR MY AUTOMATIC I SHOULD LOOK INTO GETTIN 4.10s right?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 09:58 AM   #8
Yes unless your on the hwy alot
Old 05-31-2011, 09:58 AM   #9
shaqfu's Avatar
i believe that is correct choice
work in progress...
Old 05-31-2011, 09:58 AM   #10
anyone know if these r good gears? or would you recommend something else? ill buy the tlok, then gears, then ill save money to install them - who ever installs the gears has to re-program the speedometer right?
http://www.americanmuscle.com/motive-410-9904v6.html
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 09:59 AM   #11
i use the hwy to get to work a lot... so i should look into 3.73?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 10:01 AM   #12
I personally would. Mine has 3.73 in it. I'm going to 3.55 or 3.23
Old 05-31-2011, 10:08 AM   #13
i have an auto v6 - so 3.73? is there big difference between 3.73 and 4.10?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 10:13 AM   #14
Rpm wise yes. Higher rpm on hwy. I know a lot of v6 owners that use 4.10s and love them. I use the highway alot so 3.73 Is too much for me.
Old 05-31-2011, 10:17 AM   #15
Could it be bad for the car if i have 4.10 n use the hwy a lot? In the long run?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 10:21 AM   #16
Higher rpm will make the engine work harder for a longer time. So yes in a way. Plus mpg will go down.
Old 05-31-2011, 10:33 AM   #17
wereKEV's Avatar
yeah your mpg would go down quite a bit.
wereKEV is offline   Reply With Quote
Old 05-31-2011, 10:59 AM   #18
than i will probably go with 3.73, plus... its still a big improvement from stock! no?
what if i have no way of reprogramming the speedometer? would i dyno do that?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 11:05 AM   #19
kickerofdoom's Avatar
It's 12 percent taller then our stock gears and that the same gears I'm getting I can tell you after I get them in install in about a week to see what the difference is on a auto
Old 05-31-2011, 11:06 AM   #20
You can either change the gear in the tranny for about 20-30 bucks or you can buy a tuner for about 300-400 bucks
Old 05-31-2011, 11:09 AM   #21
wereKEV's Avatar
gears cheaper tuner easier it's your choice.
Old 05-31-2011, 11:34 AM   #22
is adjusting the speedometer a must after changing geaars?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 11:45 AM   #23
i was reading and stock gt gears r 3.27 so r they newer edge sn95's v6 gears... does that mean i have 3.27? sorry for the dumb question...
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 11:46 AM   #24
wereKEV's Avatar
you should I would think it would throw it off quite a bit.
Old 05-31-2011, 12:03 PM   #25
You have 3.27 gears
Old 05-31-2011, 12:09 PM   #26
Yes. If you want your car to shift right
Old 05-31-2011, 12:13 PM   #27
so basically if i dont have a programmer im screwed? lol
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 12:16 PM   #28
No. Like I said. You can buy a speedo gear for 20-30 dollars
Old 05-31-2011, 12:17 PM   #29
ooo, where can i find that?
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 12:18 PM   #30
Dealership or online. I'll find the website for you in a min
Old 05-31-2011, 12:19 PM   #31
Am has one eBay has a tlock for sale for 100 check it out man
Old 05-31-2011, 12:24 PM   #32
I would wait until you can afford both, its the same basic install for both so just save a little longer
Old 05-31-2011, 12:25 PM   #33
im just gonna buy one then the other - and have them installed at the same time... im just trying to figure out the "adjusting the speedometer" part
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 05-31-2011, 12:32 PM   #34
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
speedo gears for all makes and models
Old 05-31-2011, 01:35 PM   #35
you either adjust the speedometer by a tune or by a speedcal unit. 99+ V6 cant use speedo gears they are digital.
3.73 TLok pringle9666 Pre-2005 V6 Mustang 9 12-31-2010 10:27 PM
Considering new gears and a TLOK. Help? tvsr Pre-2005 V6 Mustang 15 12-31-2010 02:21 AM
gears and tlok 1997grnstang Pre-2005 V6 Mustang 15 04-11-2005 11:10 PM
Want 3.73 gears and tlok ttpancakes Mustang Parts for Sale and Wanted 4 08-15-2004 02:36 PM
Posi / Tlok Donny B Pre-2005 V6 Mustang 3 12-02-2003 08:06 PM
03:56 PM
