what's next - Mustang Evolution
Old 06-01-2011, 07:50 AM   #1
kickerofdoom's Avatar
what's next
I got a 2001 mustang v6 auto with dual exhaust,short header,cai,tuner,17 inch rims,adding gears and tlock and subframe connector soon what should be my next mod..
Old 06-01-2011, 09:04 AM   #2
Re: what's next
lowering springs
Old 06-01-2011, 09:41 AM   #3
What kind is cheap but good without doing too much
Old 06-01-2011, 08:44 PM   #4
Re: what's next
Ford Racing C or B springs would give you some drop and aren't overly expensive. You can probably get away with just replacing the springs and none of the other components.
Cut springs would be the cheapest route, but the length of spring is changed while the load is not (not good for your suspensio) and you will wear out your shocks/struts real quick, not to mention the ride would probably be pretty harsh.
Old 06-02-2011, 05:53 AM   #5
I will look in some shock first then spring
Old 06-02-2011, 07:05 AM   #6
Re: what's next
make sure you pair the shocks/struts with springs as far as which you buy as they need to be setup close to the same for the optimal performance.
Old 06-02-2011, 07:56 AM   #7
Are kyb good with Ford spring
Old 06-02-2011, 08:23 AM   #8
A.K.A. Baby-D!
Re: what's next
lowering springs is def. the right route to take next.
don't forget CC plates depending on the amount of drop
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
03:12 PM
