98 Mustang Manual 3.8L V6 - startup problems - Mustang Evolution
Old 06-03-2011, 06:38 PM   #1
I just started having problems starting my Mustang. Sometimes the car will not turn over. It's not a battery problem. When I played with the shift and moved it around several times it finally started. This has happened to me 3 times in the last week. Any ideas? Thanks!
tinabfla is offline   Reply With Quote
Old 06-03-2011, 11:22 PM   #2
Greg687's Avatar
Region: New Mexico
Re: 98 Mustang Manual 3.8L V6 - startup problems
neutral safety switch? when you play with the gears are you moving the clutch pedal at all? they have a switch that won't let the car start unless the clutch is disengaged (pushed down)
Greg687 is offline   Reply With Quote
Old 06-04-2011, 10:29 PM   #3
bradh2414's Avatar
I have the same car. But yeah check to make sure the inertia switch in the trunk is down and if it isn't that then you might just need a tune up if it hasn't been done in a while. And if all else fails it might be time for a new starter
bradh2414 is offline   Reply With Quote
Old 06-05-2011, 10:48 AM   #4
Hi Greg687,
I had the clutch pushed down like I always do, so I tried pumping the clutch just to see if that would help, but it didn't. I heard other possibilities could be something to do with the neutral switch or the wiring in the ignition switch? Thanks for your help!
Old 06-05-2011, 09:42 PM   #5
Greg687's Avatar
Region: New Mexico
ignition switch would be a good guess.
Hesitation at startup gtstyles2 2011-2014 Mustang GT 7 06-01-2011 07:20 AM
changing manual shifter-knob 08 mustang brandon0404 Pre-2005 V6 Mustang 1 07-08-2008 08:16 PM
need a mustang service manual I_luv_HP&trq Pre-2005 V6 Mustang 14 09-19-2005 01:56 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
08:13 PM
