How long does the clutch last? - Mustang Evolution
Old 10-31-2003, 07:40 PM   #1
I have a 2000 v6 with 5 speed. I bought the car used with 58,000 on it and it currently has 68,000. I have noticed on occasion that reverse is hard to get into. I find it easier to put it in reverse and then start the engine. I dont notice any slippage of the clutch in any of the gears.
Is there a way to tell when its going to go, or is there a way to check the clutch free play
Thanks
Steve
sctalbott is offline   Reply With Quote
Old 11-01-2003, 08:59 AM   #2
its not realyl a clutch issue, first and revese, and 2nd are hard to get into on our trannys, i would change the fluid with some amisoil, gm syncromesh, or some full synthetic lubricant to help, especially on cold days. try putting it in first then reverse, you cabn check to make sure yoru clutch travels far enough but it should be fine, lift up on the clutch petal to adjust it if thats better than you are set, if it unadjusts its self shortly then the quadrent is worn and you need a new one or live with it.
if you treat it will a clutch will last 100k
Old 11-01-2003, 11:35 AM   #3
Zim
You want to **** me?
Zim's Avatar
clutches are usually good for around 60k...
your problem, however, doesnt sound clutch related
I like toys
Old 11-01-2003, 11:41 AM   #4
i have seen clutches last 120-130k but usually if you get 60-80 just consider yoru self lucky and spend the 150 bucks~ for a new one.
Old 11-01-2003, 01:40 PM   #5
Send a message via AIM to domin8stang
yeah what u are explaining sounds to me like u need to go into first and then reverse to move the linkage around....thats all....
FOR SALE : 03 V6 Bumper & 16x7.5 Stock Rims w/o Tires! PM FOR INFO!
http://www.mustangmods.com/data/1573/newsig.jpghttp://www.mustangmods.com/data/1573/imretarted.jpg
2003 Silver Mustang
Cobra R Bumper, Eibach Sportlines *SELF INSTALLED*, Spintech Dual Exhaust!, Mac CAI, Mac CC plates, Raised pedal ,Offset Rack, 18" Saleen Replicas WOOT!
domin8stang is offline   Reply With Quote
Old 11-01-2003, 07:32 PM   #6
Thanks so much for the replies back. I will look into changing the trans fluid. It doesnt do it all the time, but it is very annoying sometimes when trying to get into reverse.
I noticed that a lot of you have tlocks? Exactly what are they, and what kind of gain if any do they provide? I am thinking of also getting the asp underdrive pulley set, also. From what I have seen, they dont provide a lot of hp gain, but improved response througout the rpm range?
That will probably be it for me as far as mods go.
Thanks again.
Steve 8) 8)
Old 11-01-2003, 08:44 PM   #7
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
my clutch lasted 134k
Rellik is offline   Reply With Quote
Old 11-02-2003, 10:33 AM   #8
transfluid is easy to change in a manual only holds 3 quarts, if yo udo it your self you need a pump thing though, no big deal just remember that before you go and drain teh fluid wiht no way to fill it back up.
Old 11-03-2003, 08:28 PM   #9
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
A t-ok is a limited slip that goes in to your rearend differencial. What it does it is when your drive wheel (the right rear) is slipping then your other will start spinning to give you extra traction. as for performance gains it will help you launch but thats about it. but dont get me wrong its a really nice thing to have. I dont really know anything about the u\d pulleys sorry.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 11-03-2003, 08:57 PM   #10
Zim
Zim's Avatar
thats traction control, not traction lok
I like toys
Old 11-04-2003, 10:55 AM   #11
tire's Avatar
Send a message via AIM to tire
um, clutches last for however long the driver allows (how they drive, if they race, and sometimes clutches just go). where did you pull 60k from? on a regular car that isn't beat on too bad 100k miles is more like it.
tire is offline   Reply With Quote
Old 11-04-2003, 11:00 AM   #12
Zim
Zim's Avatar
it obviously matters how you drive it, but a person thats gunna get on the gas quite often will see a lower life of their clutch. i got 60k from one of our other cars. thats where the clutch went out on that. 60k-75k is a pretty safe average
I like toys
Old 01-17-2004, 09:06 AM   #13
Send a message via Yahoo to plstktnkr2
my clutch lasted 135k no problems
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 01-17-2004, 10:59 AM   #14
Danger Dude's Avatar
Totally agree with this statement. Clutchs last however good or bad you treat it. Speed shifting will dramatically decrease the life of the clutch and glaze the flywheel requiring it to be resurfaced or replaced
Old 01-17-2004, 01:33 PM   #15
reverse = the suck in our cars i have an awful time getting mien to go in, in the manual it says to hold it all the way to the left, to the left of 3rd and 4th for 4-5 seconds before putting it in reverse any time it is in the middle it has reverse blocked off or some crap....
Old 01-17-2004, 02:36 PM   #16
Dom
Dom's Avatar
Send a message via AIM to Dom
But hey, makes a cool sound when your trying to get it in reverse.
Old 01-17-2004, 11:11 PM   #17
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
lol @ yall can't get your cars in reverse
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 01-18-2004, 08:16 PM   #18
Dom
Dom's Avatar
We don't need reverse, what do you think we have Evo VIII that can go 80 in reverse?
Old 01-19-2004, 03:11 PM   #19
average: clutches will last 100-130k
Could die before or after.
My clutch went at: 134k
Old 01-19-2004, 04:12 PM   #20
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Acctually, no, that's t-loc.
Traction control pumps your ABS brakes and shuts down cylinders to reduce power and prevent spinning.
T-loc uses clutches to make sure that if one wheel loses traction power will be transfered to the other wheel.
And it's great, I love mine.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-19-2004, 05:50 PM   #21
Check out this link
You gotta here this. about how dumb this person is, in regards to knowing about her car
http://www.ebaumsworld.com/mechanic.html
Old 01-19-2004, 05:51 PM   #22
forgot to put in the link
Old 03-06-2004, 08:13 PM   #23
Send a message via AIM to 232SCstang
Rellik,
Hey rellik, where did you get those headlight lenses?
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
How long has it been? MarkuzLS1 The Bar 38 08-09-2007 05:10 AM
Biggest WTF I've seen in a LONG, LONG Time. Zim Pictures and Videos 35 03-09-2007 07:00 AM
what would you think? (very long) maximus 1996-2004 Mustang GT 15 01-30-2007 05:21 PM
How all has a gf/bf and how long have you been together? SpectorV The Bar 32 12-21-2004 12:51 PM
How Long Until... Austin The Bar 6 06-16-2004 09:45 AM
09:54 AM
