Rear brake caliper anchor bolt size/help - Mustang Evolution
Old 08-21-2007, 05:24 PM   #1
Send a message via AIM to CakeOrDeath?
Recently the top anchor plate bolt on the right rear brake caliper managed to disappear, I don't know if it vibrated out somehow or what. Anyway, I am trying to figure out how to get a hold of a replacement bolt for it. I found the whole bracket with bolts for sale but I can't find just the bolt so in order to save some money I was hoping someone here could tell me if they knew what size the bolt was so I could buy a replacement.
Here is the bracket from the Autozone site: http://www.autozone.com/R,APP1190289...ductDetail.htm
I also attached a picture of the front anchor plate bolt (circled), I don't know if that helps or not, I would think the front and rear bolts would be the same size, but I dunno.
I consulted my Haynes manual and a million different online sources and couldn't find the specs on that bolt, and I am trying to avoid having to take apart my other caliper to bring that bolt in to measure it and I can't remove the bottom bolt because it is blocked by the brake line so any help you guys could give me would be great. Thanks!
CakeOrDeath? is offline   Reply With Quote
Old 08-21-2007, 06:44 PM   #2
crazeflier07's Avatar
Send a message via AIM to crazeflier07
Re: Rear brake caliper anchor bolt size/help
You know I had the same thing happen to me. Was driving around and didnt notice a thing, and then someone pointed out my caliper was hanging! Wore out the brake pads sideways too. Dont know the specs but if give ford a call they might help you out if they arent jerks about it.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
~CAI, True dual exhaust, UDPs, MGW Shifter, H&R springs, Stage 1 & 2 supension kit, performance rotors & pads, steel braided lines, 1 inch rear spacers, A.R. Rebel 17x9s with BFG rubber! :thumbs2:
crazeflier07 is offline   Reply With Quote
Old 08-21-2007, 11:02 PM   #3
So...how did you get the replacement bolt?
I have looked through the Motorcraft part catalog and all I can find is the BRPK5618A Rear Brake Hardware kit and it doesn't appear to have the correct bolt in it.
Old 08-23-2007, 10:20 PM   #4
Guy I was friends with who had a shop got one from me from NAPA and when I had my car on his lift we fixed it. Try them out they probably have it.
~Jon~
Sinister Six
1998 3.8L V6
Done So Far:
Old 08-25-2007, 10:57 AM   #5
Thanks for the help guys!
I ended up figuring out that it is a M12 x 1.75 x 35mm bolt but none of my local auto parts stores had that size (only 30mm and 40mm ) so I called around to my local Ace hardware and they had the exact size bolt in stock there. So I bought the hardened bolt and installed it and it seems to be working perfectly.
Old 09-01-2007, 01:04 AM   #6
Region: New Hampshire
Send a message via AIM to Smokedya95stang
throw some thread locker on them before u install them if it just rattled out! lol.
-Charles
Smokedya95stang is offline   Reply With Quote
brake caliper paint question bluestang1724 Pre-2005 V6 Mustang 11 03-23-2011 12:53 PM
Brake upgrade and tire size question? runvsofthisbull Pre-2005 V6 Mustang 4 11-29-2006 03:49 PM
Size of bolt that grounds computer Brent Pre-2005 V6 Mustang 3 12-12-2005 02:32 PM
Brake Caliper Paint? FloMasta24 Mustang Audio & Video 21 09-12-2004 05:06 PM
bolt size on upper intake whipster24 Pre-2005 V6 Mustang 10 11-21-2003 11:36 AM
06:58 PM
