Factory Radio... - Mustang Evolution
Old 08-23-2007, 12:56 PM   #1
Send a message via AIM to V6Polish
Factory Radio...
I have a 1996 v6 mustang and I had an aftermarket radio but it stoppe working, so i am putting the factory radio back in.
When i bought the car it only had the factory tape player...i bought a cdplayer to go along with it (factory)
the only problem is that there are 2 connections on the back of the cd player and no wires to plugin.
Now...on the tape player there are 3 connections, only 2 of which are being used, i was told that the third one is a 'jumper wire' which will plugin to the tape player then "Y" to the 2 plugins for the cdplayer.
My problem is, there is no factory wire in my car that will allow me to do this.
My question is, where can i get this wire and is my information even correct?
Thanks
V6Polish is offline   Reply With Quote
Old 08-23-2007, 01:46 PM   #2
Herbstang's Avatar
Re: Factory Radio...
try looking here eBay Store Volunteer Automotive and Car Audio: Search results for mustang.
Old 08-23-2007, 04:31 PM   #3
I appreciate your help, but I didnt find anything.
Old 08-23-2007, 04:41 PM   #4
Your car may not have come with a cd player from the factory, meaning you will need a compatible head unit to match with the factory cd player. You'll probably come out cheaper and better just buying another aftermarket headunit to replace all of it.
Old 08-24-2007, 12:55 AM   #5
OsirisGuy's Avatar
You are going to need a harness that plugs from the back of the tape player into the CD player and from the CD player on to the speakers, unless you have an amp (which I believe anything with a CD player has) in which case you will need the harness to plug into the amp.
I'd check eBay, audio shops, swap meets, junkyards, online classifieds (for those who are no longer using theirs due to aftermarket radios), and lastly a Ford Dealership/Service center.
I'm including a bunch of attachments (actually one big .pdf file) for the radio wiring I have I printed out from All Data a while ago. Hope that's okay. Hope it helps.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-24-2007, 02:34 PM   #6
Ford house said they cannot order it, they can only order the entire harness costing 500+ dollars, I have checked many places and have only one more shot, our main junk yard....hopefully ill have some luck
Thanks for your help
New here! Radio help mustangkid1993 Mustang Audio & Video 5 01-14-2010 07:42 PM
Radio HELPP Stang61 Pre-2005 V6 Mustang 22 09-20-2009 08:35 PM
removing factory radio from 84 lx need help Doken Mustang Audio & Video 2 04-26-2008 05:32 AM
XM Radio meteorachick The Bar 22 05-24-2007 12:02 AM
XM radio Zim Mustang Audio & Video 21 01-18-2005 07:58 PM
11:33 AM
