Rear End - Mustang Evolution
Old 08-24-2007, 08:37 AM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Rear End
My long term plan for my car includes making upgrades to my rear end. One of the upgrades I'd like to do is making the transition to an 8.8'' rear end. Someone told me all I had to do was simply to change the center piece of the rear end. I don't know the terminology but ---0--- if that were the rear end it would be the ' 0 ' that would need to be replaced only. (The pumpkin. Just found out.) While swapping that out I'd change the gears to a 3.73 and a T-Lok. Can anyone tell me more about the process I'd have to go through to make this change?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 08-24-2007, 10:08 AM   #2
hottcobra's Avatar
Re: Rear End
when you say a pumpkin it usually refers to a Ford 9" do you want an 8.8 Live axle or and 8.8 IRS?
Old 08-24-2007, 10:28 AM   #3
Herbstang's Avatar
Re: Rear End
It's not that simple !!! Look for a wrecked 2004 GT get the 8.8 Then it will be a simple swap so far as the rears have a shop do it read this 8.8" Rear Axle
Old 08-25-2007, 09:30 PM   #4
Re: Rear End
You will need a rear end from a 99-04 GT in order to make this work. Be ready to spend at least 600 dollars for a rear end in good shape unless you can find a hookup. You will be much better off buying a complete rear rather than having to piece one together in the end.
Old 08-27-2007, 09:20 AM   #5
megax29's Avatar
Re: Rear End
Someone told me I just needed to change the center part of the axle and that was it...I guess it's not that easy. Would making the change to a 8.8" be beneficial to my cars performance or would it only benefit by making it more durable. Would the performance to cost ratio be greater with an IRS system or regular?
V6 Midnight Black
Old 08-27-2007, 09:27 AM   #6
Y2E0L0L5OGWT's Avatar
Re: Rear End
what are you wanting to do with the car? your end goal will decide your course of action as far as deciding what type of rearend to go with...
if you are wanting to build a strictly straight line drag car, than an IRS will be useless as you will brake axles left and right...you will want a solid axle for this purpose...
if you want a car that is made for handling twisties and smooth acceleration rather than sudden hard acceleration in a straight line, you would probably be more justified in going with and IRS...
When you say "an IRS system or regular", I assume by regular you are meaning a solid axle?
Old 08-27-2007, 02:46 PM   #7
megax29's Avatar
Re: Rear End
Looking to build a fun all around car for street fun and not strictly for racing on the strip. Definitely not a drag car...more like a street car. So how do I go from a 7.5" solid to a 8.8" IRS?
V6 Midnight Black
Old 08-27-2007, 06:22 PM   #8
Re: Rear End
buy the entire 8.8 rear end and be done with it.
Old 08-27-2007, 07:19 PM   #9
Re: Rear End
IRS is a much heavier system than your factory rear end. If you are wanting to go this route be ready to spend around 1000 dollars for the entire setup. Yes, it will make a difference in handling, but, you can make the same difference with a solid rear if you want.
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
GT rear end CajunMustang Pre-2005 V6 Mustang 2 11-04-2004 11:34 AM
99-04 8.8 Rear end ManofManyStangs Mustang Parts for Sale and Wanted 3 10-20-2004 06:32 PM
8.8 Rear End ttpancakes Mustang Parts for Sale and Wanted 8 07-20-2004 06:39 PM
what is in my rear end. Black00GT Pre-2005 V6 Mustang 9 03-18-2004 03:33 PM
07:33 AM
