No start on a '99 - Mustang Evolution
Old 08-29-2007, 09:25 AM   #1
No start on a '99
Well my girlfriend called me today and said her car wont start. I went over to her house and when i turned the key it only clicked. So i tried jumping it and still only a click. i thought it was the battery but all her electronics work, so i kinda ruled that out. So im not sure what it is next, her alternator or her starter, or something else. Please help her/me out cause she has to get to class.
Thanks
4doorsleeper is offline   Reply With Quote
Old 08-29-2007, 09:45 AM   #2
Herbstang's Avatar
Re: No start on a '99
Might try this on the starter there is a fusible link. It looks almost like another wire but it actually there to protect the electrical system.
Is the THEFT light flashing ??
Troubleshooting A No-Start Problem
Old 08-29-2007, 10:11 AM   #3
ill check on the anti-theft light....but i did notice that the panic button on the remote doesnt work anymore also
Old 09-12-2007, 09:54 PM   #4
check the battery/ starter/ wires for good connections, make sure there isn't any corrosion. then if you have a multi meter check voltage at battery terminals if good there check the voltage at the starter while cranking if thats good replace the starter, most likely its the starter but ive seen people spend money on a starter when it was just the wires( wires are cheaper )
jedwards242000 is offline   Reply With Quote
Old 09-15-2007, 02:06 PM   #5
97Stallion's Avatar
If the engine is not grounded properly it won't start either.
Living one day at a time!
My 99 won't start!! j_worrr 1996-2004 Mustang GT 13 12-28-2009 11:40 AM
where do i start? corey-b25 General Mustang Discussion 2 02-28-2008 09:59 PM
V6 won't start...help stang man Pre-2005 V6 Mustang 2 11-26-2006 01:15 PM
where to start lowflyn Pre-2005 V6 Mustang 4 08-22-2003 05:42 PM
12:19 PM
