lower intake manifold leaking coolant - Mustang Evolution
Old 06-16-2011, 05:19 PM   #1
I noticed some coolant leaking out the front of my engine, where the lower intake manifold attaches. When I took off the manifold, the gasket had corrosion around the areas where the coolant was in the front near the water pump [the oil areas looked fine.]
Any idea what might have caused this? I had cleaned and sanded and brake-cleanered everything, and carefully followed the directions for laying out the gaskets and RTV'ing the corners, and torquing everything down.
Is there a trick I'm missing? I'm trying not to put it all back together and have the same problem pop up.
shustwit is offline   Reply With Quote
Old 06-17-2011, 05:43 AM   #2
kickerofdoom's Avatar
Are u sure its there I have a small leak too and if I look carefully its a tube leaking
Old 06-17-2011, 11:12 AM   #3
junoS197Bl08's Avatar
Re: lower intake manifold leaking coolant
what year is ur car?
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-17-2011, 11:18 AM   #4
Send a message via Skype™ to Texastboneking
Sounds like your coolant was contaminated. Make sure when you put it back together to flush the system clean and start with long life coolant. If you use low life coolant just be sure to flush and replace yearly to keep this problem from reappearing. Changing your coolant is more important than ppl realize.
Texastboneking is offline   Reply With Quote
Old 06-17-2011, 11:28 AM   #5
It's a 96
Coolant leaking 08v6 1979-1995 Mustang GT 2 06-05-2011 03:42 PM
lower intake manifold corner bolts?? desperate for help!!!! Pascullon Pre-2005 V6 Mustang 0 02-18-2011 12:00 PM
FS: Splitport P&P heads and Lower intake manifold hawks05 Mustang Parts for Sale and Wanted 5 12-15-2006 08:24 AM
So my lower intake manifold... MonteCitan 1979-1995 Mustang GT 3 11-20-2006 08:22 PM
Leaking Exhaust Manifold? 00vertstang Pre-2005 V6 Mustang 8 06-04-2005 07:16 PM
01:53 PM
