Please help! Power loss! V6 - Mustang Evolution
Old 06-20-2011, 12:18 PM   #1
I also noticed a difference after my rims were put on. It drove fine before. I have stock exhaust but it sounds like I have aftermarket. It sounds cool. It drive fine before but for the past two days the exhaust sounds way different, and Its not as fast! It takes longer to get going from 1st gear. Could it be that they smashed the exhaust when they lifted my car to put the rims on? Or could it just be my spark plugs? Its hard to describe what it's doing but my brother even noticed that it sounds and drives different. I took it to a local tire shop (Hibdon tires). The exhaust sounds deeper. It sounds like either too much air is getting through or not enough. I can't tell. But when I start out in first gear it sounds more like a tick tick tick tick and then it stops when I get up to speed and it does it in every gear until I get up to speed. Or maybe I'm just imagining it but I doubt it. Please help
sickV6 is offline   Reply With Quote
Old 06-20-2011, 12:21 PM   #2
Send a message via Skype™ to Texastboneking
Originally Posted by sickV6
I also noticed a difference after my rims were put on. It drove fine before. I have stock exhaust but it sounds like I have aftermarket. It sounds cool. It drive fine before but for the past two days the exhaust sounds way different, and Its not as fast! It takes longer to get going from 1st gear. Could it be that smashed the exhaust with the lift? Or could it just be my spark plugs? Its hard to describe what it's doing but my brother even noticed that it sounds and drives different. I took it to a local tire shop (Hibdon tires). The exhaust sounds deeper. It sounds like either too much air is getting through or not enough. I can't tell. But when I start out in first gear it sounds more like a tick tick tick tick and then it stops when I get up to speed and it does it in every gear until I get up to speed. Or maybe I'm just imagining it but I doubt it. Please help
Sounds like a busted muffler and clogged cats. But it's hard to be sure without seeing it in person
Texastboneking is offline   Reply With Quote
Old 06-20-2011, 12:22 PM   #3
That's what I told my dad but he thinks it's an attempt to get new exhaust lol. But how would my cats be clogged? I haven't done anything to get them clogged
Old 06-20-2011, 12:25 PM   #4
Just old age. They clog overtime. You don't have to do anything to clogg them.
Old 06-20-2011, 12:29 PM   #5
It only has 89,000 miles on it. So how do I go about cleaning it? Or fixing? It just started out of nowhere. I guess you could describe it as trumpeting or a tick tick sound when I accelerate
Old 06-20-2011, 12:29 PM   #6
Re: Please help! Power loss! V6
after driving a while at night pop the hood and see if the header is looking hot (orange glowing = bad)
if clogged you have to replace the cat, you can go to a junk yard and get a Y pipe from another mustang or remove/replace yours.
Old 06-20-2011, 12:31 PM   #7
Should I just take the cat off and add a mid pipe to it?
Old 06-20-2011, 12:32 PM   #8
you can but you will have a check engine light without the cats
Old 06-20-2011, 12:33 PM   #9
If you drive a lot of short range and don't really get the car hot it will clog up faster. And you have to just replace them. But usually your check engine light comes on.
Old 06-20-2011, 12:34 PM   #10
I don't care about the check engine light. I just want the problem fixed and I hope it's nothing major. And I can hear air escaping when I shut my car off but I think it's just the AC because I always have the AC on.
Old 06-20-2011, 12:37 PM   #11
austinknoll's Avatar
I think he's rght they just are destroyed. My cats are broken so I have a check engine light on and I only have 77000 miles. But I don't need catsfor the next year because then I have to get it smogged stupid California
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 06-20-2011, 12:40 PM   #12
So if I look at the cats ad they are pure black then I know I need to get a new pipe or replace it. Think I'm just gunna get a pipe for it and do it that way and hope it fixes it
Old 06-20-2011, 12:40 PM   #13
What I was getting at is if the light is on you can get it scanned and it will give you an idea of what is wrong...
Old 06-20-2011, 12:41 PM   #14
Mo. They will be blue and purple colored usually. And if you drive it at night it can turn cherry red.
Old 06-20-2011, 12:42 PM   #15
90 dollars for a diagnostics. Lol so I'm pretty sure it's the cats by now since everyone is saying it. I can't remember if my check engine light is on or not
Old 06-20-2011, 12:47 PM   #16
That's what I'm guessing from what you explained. But it might not be it.
Old 06-20-2011, 12:48 PM   #17
Also if any of your front o2 sensors are bad you need to replace them. The rear two arnt important for the running part of your car. But the front two can mess up your air to fuel ratio. Causing problems
Old 06-20-2011, 01:12 PM   #18
I think I'm gunna go with replacing the front O2 censors first and see what that does
Old 06-20-2011, 01:22 PM   #19
I'd pay the 90 dollar diag. Your gonna spend more in parts and might not fix it. My .02
Old 06-20-2011, 02:22 PM   #20
That's true. Now I started my car and let it idle for a few seconds. I put my hand over the exhaust pipe to check the airflow and it was fine. There was plenty of airflow coming out so I don't think it's the cats, but I also know that the airflow could be fine until I accelerate and then become constricted under acceleration. I have not tested it under acceleration yet.
Old 06-20-2011, 02:35 PM   #21
It will flow if it's clogged still. it's not completely plugged. It's when your accelerating that it flows bad. It will make a sound like it is burping through the intake when you floor it if it is clogged.
Old 06-20-2011, 02:47 PM   #22
Ok. So Here is my plans. Diagnostics test and then buy parts ad voila car fixed hopefully lol.
Old 06-20-2011, 02:49 PM   #23
Autozone scans computers for free by the way. Give me the codes and I might could tell you what's up
Old 06-20-2011, 03:04 PM   #24
I'll have to do it tomorrow cuz I've got homework and class tonight
Old 06-20-2011, 09:07 PM   #25
My check engine light is not on...
Old 06-20-2011, 10:34 PM   #26
Make sure the bulb is not out. Turn the key on. Don't start it. And see if the light illuminates.
Old 06-20-2011, 11:11 PM   #27
It illuminated when I turned the key and then I started it and the light went off
Old 06-20-2011, 11:14 PM   #28
well then i think its best to get the diag then...
power loss...maybe? blackonblack Pre-2005 V6 Mustang 8 05-14-2011 10:09 PM
V6 Loss of horse power wyatt-00' Pre-2005 V6 Mustang 19 01-27-2010 08:29 AM
Loss power and overheat, jerking, please help!!! kevpar07 Pre-2005 V6 Mustang 4 09-08-2007 10:25 PM
93 POWER LOSS jcori3 1979-1995 Mustang GT 17 09-19-2006 06:41 AM
power loss? 6erstang Pre-2005 V6 Mustang 7 09-03-2003 09:39 AM
10:05 AM
