running hot - Mustang Evolution
Old 06-21-2011, 07:15 AM   #1
A.K.A. Baby-D!
running hot
My 04 V6 has been having some temp issues. If i sit idle for more than 5 minutes my temp needle starts climbing. I've checked my fan and it is working. I haven't found any leaks, and radiator and overflow reservoir were both at good levels. I changed the thermostat just to be sure as well. I've also changed the radiator cap. Nothing seems to fix the issue. Any ideas guys?
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 06-21-2011, 09:25 AM   #2
Re: running hot
Sounds like a thermostat issue from your description since you confirmed the fans are working.
Old 06-21-2011, 09:35 AM   #3
A.K.A. Baby-D!
Re: running hot
brand new OEM thermostat installed.
Current:
Previous:
Old 06-21-2011, 10:39 AM   #4
Re: running hot
well sounds like you got a leak somewhere down the line. make sure you sealed the thermostat properly and put it together right!
jaiveson is offline   Reply With Quote
Old 06-21-2011, 11:17 AM   #5
Send a message via Skype™ to Texastboneking
Waterpump blades might be rusted off and not moving the water fast enough to cool it down.
Texastboneking is offline   Reply With Quote
Old 06-21-2011, 11:33 AM   #6
Re: running hot
How newly installed? You could have an air pocket in the system if it was installed right before the problem arose.
Old 06-21-2011, 11:45 AM   #7
Re: running hot
yea you can remove the little bolt facing upwards in front of the upper intake (highest point of the coolant system) and pour fluid in there etc just dont do it when its warm.
Old 06-21-2011, 11:49 AM   #8
gqsmash's Avatar
When you reinstalled t-stat did you lose a lot of coolant? If you did did you make sure to you filled it back up completely? I had to dump the juice out of my diesel like three times and I had to let the engine heat up so I could fill my heater core back up and it lowered my coolant level like a gallon and a half....so not sure how much you lost but just chiming in to throw out some ideas
gqsmash is offline   Reply With Quote
Old 06-21-2011, 12:31 PM   #9
A.K.A. Baby-D!
Re: running hot
thermostat is sealed properly and no leaks around.
how do i check this?
the thermostat was replaced 2 weeks ago, and the problem was occuring before that. I made sure of no leaks all around after installing the thermostat, and i also purged the system to release all air.
i used that bolt to purge.
didn't lose much coolant, and yes it is full. radiator is topped off and reservoir is at the correct level.
thanks for all the input guys! hoping to find a solution soon!
Current:
Previous:
Old 06-21-2011, 12:47 PM   #10
Let it start getting hot. Idle the car to about 2500 rpm. Does the temp go down or up??? If down it's most likely the pump blades. If up something else.
Old 06-21-2011, 01:17 PM   #11
A.K.A. Baby-D!
Re: running hot
ok will try that this evening! thanks!
Current:
Previous:
Old 06-21-2011, 01:21 PM   #12
Welcome!
Old 06-22-2011, 06:30 AM   #13
A.K.A. Baby-D!
Re: running hot
well my car did the usual of making a liar out of me lol...
i had only driven her once since i changed the thermostat and once i saw the needle began to creep up i guess i assumed too soon that there was still a problem. sat at idle for almost 20 minutes yesterday. the needle did begin to climb, but i guess the thermostat did its job and i saw the needle go right back to the normal position shortly after. so after all i guess the new thermostat did do the trick.
sorry for the unneeded questions guys but thanks for your responses and input anyways!
Current:
Previous:
Old 06-22-2011, 06:33 AM   #14
Lol glad it works now
Running Hot Gray Ghost 1979-1995 Mustang GT 13 01-14-2011 12:02 AM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
Running the V-6 05STANG Pre-2005 V6 Mustang 5 02-13-2006 07:36 AM
Running Hot.... Shortie630 Pre-2005 V6 Mustang 12 03-25-2004 10:19 PM
» Members Mustangs
Name?
meno1994
Amber
Starion
Add your Mustang
11:35 PM
