lowering - Mustang Evolution
Old 06-22-2011, 01:23 PM   #1
bradh2414's Avatar
lowering
I know there are other threads about this out there but I didn't know if they were car specific.
I have a 1998 v6 mustang and I wanna lower it a little. What's the best way? Lowering springs? If so what's the work to do it like, how expensive is it, and what's a good brand to buy for my car???
All advice is helpful thank you
bradh2414 is offline   Reply With Quote
Old 06-22-2011, 01:40 PM   #2
Jamesgt08's Avatar
Yea lowering springs are the best way to go. I would use eibach. Check out american muscle for prices. If ur on a budget late model resteration ha some springs for 100 bucks which aint bad. I woul also suggest cc plates if you go low. But the labor isnt to bad. I did my car in about 2 hours.
Jamesgt08 is offline   Reply With Quote
Old 06-22-2011, 02:53 PM   #3
kickerofdoom's Avatar
Ford springs are nicer then u don't need cc plates and a lot of other extra stuff.
Old 06-22-2011, 03:43 PM   #4
Re: lowering
you can cut your springs a bit, if you cut them with a cut off wheel it wont hurt anything, you cant use a torch.
If you want to help handling you can buy some ford racing C springs for cheap (150 or so) they are 600lbs front 300~ rear so much stiffer than stock (400 or less in front)
If you drop it more than 1 inch you may require caster/camber plates (190 bucks) to get the alignment right.
I would say go at least 1.5 inches or dont bother
for cutting the stock springs I cant tell you how much to cut but i am sure someone can... it may be a trial and error thing but dont cut to much you can always cut more but not put it back on lol.
there is a how to I wrote, its rather easy. look in the article section
Old 06-22-2011, 03:52 PM   #5
bradh2414's Avatar
I might not because my ride is harsh enough as is and if new springs make it stiffer that would be a rough drive
Old 06-22-2011, 03:58 PM   #6
Jamesgt08's Avatar
I cut my stock springs at first it was ok for a while then my shocks and struts went out the springs were to weak and it was really bouncy but the car looked sexy lol. I would invest in some good lowering springs and some cc plates. IMO
Old 06-23-2011, 07:22 AM   #7
Re: lowering
you can get springs that dont raise the spring rate so the ride wont be any worse than it is. Currently its super soft and easy riding compared to many stiff springs out there lol, if you think its a harsh ride now... yea dont go with performance oriented springs.
of course some of your harshness might be the stock shocks/struts are just worn out and or froze up causing a very harsh ride... inspect them to check for this.
Old 06-23-2011, 09:03 AM   #8
bradh2414's Avatar
My struts and shocks are in pretty decent shape still. And what brands should I go with to not harshen the ride?
lowering help!!! 98gtdriver 1996-2004 Mustang GT 9 06-16-2011 07:23 AM
Lowering my 04... 04SonicBlueGT 1996-2004 Mustang GT 22 10-23-2009 12:31 PM
Lowering my 04 GT Talon 1996-2004 Mustang GT 13 07-15-2009 08:02 PM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
Lowering? 19ClearCobra96 1996-2004 Mustang GT 14 05-16-2005 06:54 PM
05:57 AM
