P1151 - Mustang Evolution
Old 06-22-2011, 02:47 PM   #1
P1151
Lack of ho2s-21 switches-sensor indicates lean (b2,s1)
What's this?
Blackedout is offline   Reply With Quote
Old 06-22-2011, 02:49 PM   #2
Send a message via Skype™ to Texastboneking
What's this?
Soposed to indicate that your second bank sensor 1 u2 sensor is reading lean. Usually caused by vacuum leaks or dirty injectors. Or a bad sensor
Texastboneking is offline   Reply With Quote
Old 06-22-2011, 02:55 PM   #3
What can I do?
Old 06-22-2011, 02:56 PM   #4
What can I do?
Well most likely the sensor is bad if your car is running normal. I would start there.
Old 06-22-2011, 04:21 PM   #5
So I got the o2 sensor but prolly got to bring it to a shop to get it put on...
Old 06-22-2011, 04:22 PM   #6
I'll do that in the middle next month when I get it all welded
Old 06-22-2011, 04:27 PM   #7
I'm on my phone and can't tell right now, but you're in BR right? Changing an o2 isn't hard, I could give you a hand if you want.
What all have you done to your car recently? I know you said a new tune. But what else?
Old 06-22-2011, 04:28 PM   #8
It's not that hard but ok
Old 06-22-2011, 04:33 PM   #9
Well I'll take another look at it later when it isn't raining...
Old 06-22-2011, 04:34 PM   #10
In st Charles parish
Old 06-22-2011, 04:36 PM   #11
Cai, pypes offroad true dual exhaust. Lol I know how to change the sensor. Jus a cramped place to get too. It's like, well ima try.
Old 06-22-2011, 04:37 PM   #12
Do you know for sure if the tune turned off the rear o2 sensors?
Old 06-22-2011, 04:38 PM   #13
Idk
Old 06-22-2011, 04:40 PM   #14
Is it the rear sensor or the sensor before where the cats should be?
Old 06-22-2011, 04:41 PM   #15
First sensor before the cat
Old 06-22-2011, 04:42 PM   #16
That came out wrong. The sensor is on the passenger side that needs to be changed tahrs what the guy at the autoparts store said... When I told him what code I had. I need to know is it the front or rear o2 sensor
Old 06-22-2011, 04:42 PM   #17
I thought so yeah that ones hard to get to.
Old 06-22-2011, 04:44 PM   #18
I know how to change a sensor it's jus a little tricky to get to
Old 06-22-2011, 04:46 PM   #19
I needa jack it up so I can get up in there.. Rain is jus off and on so I got impatient.
Old 06-22-2011, 04:55 PM   #20
If your tune is correct and disabled the rear o2s, it's the one closest to the motor.
Old 06-22-2011, 04:56 PM   #21
Ok so now what?
Old 06-22-2011, 04:57 PM   #22
Aren't all theses sensors tha same
Old 06-22-2011, 05:00 PM   #23
No, the rear o2s are slightly different.
Old 06-22-2011, 05:01 PM   #24
Ima try again
Old 06-22-2011, 05:17 PM   #25
Yeah can't get to it
Old 06-22-2011, 05:28 PM   #26
This sucks. But I'll get it done when I can bring it to the shop and take the x pipe off and change the sensor
Old 06-22-2011, 05:40 PM   #27
Can this wait for a while? Will it harm my car? Running lean it says.
Old 06-22-2011, 07:48 PM   #28
kickerofdoom's Avatar
Running lean is very bad
Old 06-22-2011, 07:55 PM   #29
+1. If you drive it keep the rpms as low as possible.
2002 V.6 codes p0175 p1150 or p1151 LittleSue Pre-2005 V6 Mustang 1 05-12-2011 10:34 AM
12:18 PM
