questions for a 98 - Driver Seat motor, Headlights, and window motor - Mustang Evolution
Old 06-23-2011, 12:47 PM   #1
Anyone know where I can buy a replacement motor for my driver seat? The one I have on still works, for the most part, If the seats back too much I press the motor button move up the seat and then the motor doesnt work for about an hour, then i can move the seat again, might this be something else? or should i just replace it?
Headlights, I have 2 pairs of the original headlights, but they have this like yellow tint on em from years of use i guess, can i get rid of this? or should i just buy some new oem headlights?
And the passenger side window no longer goes up, do i need to replace the motor for this as well, a few months ago i had this problem but it only lasted a day or two before the window worked again and it went for months until it stopped working yesterday, coudl it be something else?
StreetJMusic is offline   Reply With Quote
Old 06-23-2011, 12:48 PM   #2
bradh2414's Avatar
For the headlights try toothpaste. Brush em and the yellow should come off
bradh2414 is offline   Reply With Quote
Old 06-23-2011, 06:37 PM   #3
derekb_'s Avatar
in our shop we use a bg headlight restoration kit that runs like 24$ I believe. one kit has enough to do somewhere between 4-10 lights depending on how bad they are. it works great the only downside is you have to let them cure for 24 hours so you can't drive too far for a day
derekb_ is offline   Reply With Quote
Old 06-23-2011, 06:51 PM   #4
znpzmustang's Avatar
Re: questions for a 98 - Driver Seat motor, Headlights, and window motor
will that work for like the fogged up ones? or does it only remove the yellow? ive been trying to get my stock ones to be clear again but i have fixed about 80% of the problem but its just still there a little bit
znpzmustang is offline   Reply With Quote
Old 06-23-2011, 08:49 PM   #5
Blackheart4355's Avatar
Aluminum wheel polish (Mothers is good) use it with a polishing wheel...gets it very clear again. If it's foggy from moisture..you need to drill a small hole in the bottom of the headlight bucket to allow the moisture to drain out. Once it's dry you silicone the hole closed.
Blackheart4355 is offline   Reply With Quote
Old 06-23-2011, 10:09 PM   #6
bradh2414's Avatar
It gets the out. Try the wheel polisher to really grind it in
Old 06-23-2011, 10:13 PM   #7
i'll have to try that, they dont have moisture, they are like just slightly fogged. thanks
Old 06-23-2011, 10:16 PM   #8
thanks guys any info as to the seat and Windows?
Old 06-23-2011, 10:23 PM   #9
bradh2414's Avatar
My 98 doesn't have power seats....
And the window might be a wire but most likely the motor is shot
Old 06-27-2011, 09:52 AM   #10
shipwreck_98's Avatar
Use a jumper wire on the switch, make sure thats not the problem first.
shipwreck_98 is offline   Reply With Quote
Old 06-27-2011, 03:39 PM   #11
Are you talking about the window or the seat?....and by switch you mean the whole mechanism that contains the buttons? Or are you refering to on the power seat the lil button to move it?
07:21 PM
