01 Mustang V6 having issues - Mustang Evolution
Old 06-25-2011, 07:58 AM   #1
So I have an 01 mustang 3.8L and its giving me issues. It idles and runs fine, but when I try to romp on it a little, it sputters and the engine bogs. The injectors have been swapped along with the plugs replaced, wires, fuel filter, and air filter. Can someone help me out before I drive this car off a cliff?
Mustanglife is offline   Reply With Quote
Old 06-25-2011, 08:07 AM   #2
Send a message via Skype™ to Texastboneking
When you say injectors swapped do you mean new oem injectors or newer higher lb rating injectors? And it sounds like a dirty maf to me.
Texastboneking is offline   Reply With Quote
Old 06-25-2011, 08:11 AM   #3
Originally Posted by Texastboneking
When you say injectors swapped do you mean now own injectors or newer higher lb rating injectors? And it sounds like a dirty maf to me.
Straight swap, not new but cleaner. Whats the best way to clean the MAF? An exhaust shop blew out the exhaust and it runs way better. Its was sputtering in all ranges, but once they did that, now it only sputters when I try to get on it.
Old 06-25-2011, 08:17 AM   #4
Check engine light on? Clean the maf by buying maf cleaner at any auto parts store and spraying the sensor with it.
Old 06-25-2011, 08:20 AM   #5
Yea, its on, but its due to a leak in the EVAP system or a faulty EVAP canister. Havent found a leak yet so I am assuming the canister is going bad, but not totally sure yet.
Old 06-25-2011, 08:20 AM   #6
stampde's Avatar
Re: 01 Mustang V6 having issues
Use Maf cleaner ,you can get it at the parts store , you just spray it on ...
do you have a CEL ?? COULD BE A FAULTY MAF sensor ? fuel pump , low fuel pressure ... but I'd replace the Fuel filter first and see if that helps .......
2011 GT Auto
Old 06-25-2011, 08:22 AM   #7
Already replaced the fuel filter. Havent done a fuel pressure test yet
Old 06-25-2011, 08:27 AM   #8
No o2 or catalyst codes for sure?
Old 06-25-2011, 08:29 AM   #9
None that have been found bro. Had 1 shop pull codes, and a different shop pull codes and run full diagnostics. Only thing that came up was 0455 as the code relating to an EVAP leak.
Old 06-25-2011, 08:36 AM   #10
Try cleaning the maf. See if that fixes it
Old 06-25-2011, 08:50 AM   #11
Jusy sprayed it, bout to test it. Will let you know when I get back home
Old 06-25-2011, 09:05 AM   #12
K, sputter is about 99% gone, but, the engine still feels sluggish. Runs tons better otherwise. Any ideas on that?
Old 06-25-2011, 09:14 AM   #13
You said they blew out your exhaust? Cats bad?
Old 06-25-2011, 09:17 AM   #14
Thats what I am thinking, but the diag didnt pull anything up. However, they do sound bad, like they are hollow or something. I am going to pull my exhaust monday night since I am off work that night and see what I can see. I have a feeling that is part of the problem just because of the way it sounds.
Old 06-25-2011, 09:19 AM   #15
Have a feeling they busted your cats out
Old 06-25-2011, 09:23 AM   #16
I wouldn't doubt it, its a hole in the wall muffler shop that did my car. Gonna cost $730.00 for 4 new cats from auto zone. Unless you know some where to get them cheaper. Was thinking about cutting out the back two and just running straight pipes with only the two front cats installed. Thoughts?
Old 06-25-2011, 09:24 AM   #17
Just get an off road pipe and cel eliminators. cheaper. But keep mufflers on it cause it's gonna be loud!
Old 06-25-2011, 09:27 AM   #18
Was gonna keep the muffler. Stupid question, what is a cel eliminator? And where should I look for all this stuff?
Old 06-25-2011, 09:30 AM   #19
eBay is my friend . And a cel eliminator goes on your rear two o2 sensors to keep the check engine light off. and ou can pass emotions as long as no one looks under your car. Hole in the wall inspection places are good for that
Old 06-25-2011, 09:32 AM   #20
Lol, nice. So two cel eliminators and what brand exhaust and cats?
Old 06-25-2011, 09:34 AM   #21
Off road pipe has no cats. And for a v6 I'm not sire what exhaust sounds best.
Old 06-25-2011, 09:35 AM   #22
So search for off road exhaust for my car on ebay then?
Old 06-25-2011, 09:36 AM   #23
I know americanmuscle.com has them. Might look there. You get a discount since your on me.com
Old 06-25-2011, 09:48 AM   #24
What?!? I didnt know that, thats awesome! Already got an account with them too. Thanks a lot bro, you have been a total help. Wish there was a way to add you as a friend or something, lol
Old 06-25-2011, 09:54 AM   #25
There is. On the computer.
Old 06-25-2011, 10:18 AM   #26
Let me get my butt on a computer.then, lol
Old 06-25-2011, 10:20 AM   #27
Lol yup. And you can also thank ppm for their comments
Old 06-25-2011, 10:23 AM   #28
Ppm?
Old 06-25-2011, 10:24 AM   #29
Ppm?
Ppl lol my bad. "People"
Old 06-25-2011, 10:33 AM   #30
Gotcha, and I do appreciate everyones help that posted, though his question was answered in my original post, lol. Either way, everyones help is much appreciated, thank you all
CPO Mustang 2010 GT Premium ??? wickerman 2011-2014 Mustang GT 14 07-11-2011 10:57 PM
ordering 12 mustang v6. need opinions SoFlo Mustang 2011-2014 V6 Mustang 17 07-05-2011 08:02 AM
1990 mustang GT mustangcobra90 1979-1995 Mustang GT 12 06-25-2011 10:29 PM
Mustang or Camaro? mustang871 The Bar 13 06-25-2011 11:42 AM
05:18 PM
