My 1999 3.8 v6 - Page 2 - Mustang Evolution
Old 07-01-2011, 10:36 AM   #36
Originally Posted by Texastboneking
As long as you don't try to go 80 all the time on the highway 4.10s will work great for you. You will just be revving higher on the highway.
I wanna go faster than that and I wanna feel more pick up
Blackedout is offline   Reply With Quote
Old 07-01-2011, 10:39 AM   #37
Send a message via Skype™ to Texastboneking
You can easily go faster than 80. I'm just saying don't cruise at that speed all day. You will still be able to do over 100
And 4.10s will get you that pick up
Texastboneking is offline   Reply With Quote
Old 07-01-2011, 11:36 AM   #38
New that pick up... Will it be like a whole new car
Old 07-01-2011, 11:38 AM   #39
I think you will be impressed
Old 07-01-2011, 12:16 PM   #40
Wow u reAlly get misunderstood one here huh?
Old 07-01-2011, 12:32 PM   #41
kickerofdoom's Avatar
Some gt get better then v6 and the weight to power doesn't help gas
Old 07-01-2011, 10:59 PM   #42
cakedout's Avatar
I got it for $3200!! A steal!!..for the price of a stock cobra I can make it just as fast..and im not going to be guzzling gas like no tomarrow..although I do want the cobra r body on it il post pics tomarrow
cakedout is offline   Reply With Quote
Old 07-01-2011, 11:06 PM   #43
There's a red stock cobra 97 for 3600 it's clean
16218 is offline   Reply With Quote
Old 07-02-2011, 12:54 AM   #44
cakedout's Avatar
Keep in mind I only have 56k miles
Old 07-03-2011, 08:20 PM   #45
cakedout's Avatar
Hey what size tires should I run?..I going to buy some soon..
Old 07-03-2011, 08:28 PM   #46
cakedout's Avatar
I'm*
Old 07-04-2011, 06:24 AM   #47
shaqfu's Avatar
Re: My 1999 3.8 v6
check this out....
Mustang Wheels And Tires FAQ
work in progress...
2002 v6, Dual Flowmasters, SCT SF3/X3 Tuner, AM CAI....
next up lowering, gears...
shaqfu is offline   Reply With Quote
Old 07-04-2011, 10:51 AM   #48
cakedout's Avatar
Originally Posted by shaqfu
check this out....
That was everything I needed to know..thanks alot
Old 07-05-2011, 04:40 AM   #49
cakedout's Avatar
Texas! can I swap to a cobra motor in my ride?
Old 07-05-2011, 05:40 AM   #50
Yes
Old 07-05-2011, 01:05 PM   #51
cakedout's Avatar
Yes
What would it cost for the motor alone?..
Old 07-05-2011, 01:15 PM   #52
Used? New? Remanufactured? Short bock? Long block?
Old 07-05-2011, 03:02 PM   #53
cakedout's Avatar
Used..but im not sure which block would be better for it..
Old 07-05-2011, 03:06 PM   #54
Anyone will fit. What's your plans for power? And you will most likely need a tranny and rear diff to support the power
Old 07-05-2011, 03:25 PM   #55
cakedout's Avatar
Well I would prefer the most power I can get..and of course I would need those to support that power..The thing is im a college student that doesnt have a ton of money..
Old 07-05-2011, 03:36 PM   #56
Well I would be carefully with used cobra engines. They usually are ragged on hard. Your gonna spend over 10 grand easy possibly alot more by the time your done.
Old 07-05-2011, 11:45 PM   #57
cakedout's Avatar
Sounds like Im better off just building the v6 up..do you know if anyone still makes m112 superchargers? Or where to find one?
Old 07-05-2011, 11:52 PM   #58
Eaton still makes them. You can find them on eatons site or you can look through craigslist for one. I have a friend with an eaton m90. Don't know how good it would work for you though.
Old 07-06-2011, 12:00 AM   #59
cakedout's Avatar
Whats the difference between the m112 and 90?
Old 07-06-2011, 12:03 AM   #60
M90 is smaller but should still be enough for your sixer
Old 07-06-2011, 12:08 AM   #61
cakedout's Avatar
Yea I think I would much rather go with the bigger one..Also do you know if I will need to do any mods to my engine to get the m112 on?
Old 07-06-2011, 07:54 AM   #62
What year u got
Old 07-06-2011, 07:55 AM   #63
Nvm m112 is the one u need. They sell a kit
Old 07-06-2011, 02:49 PM   #64
cakedout's Avatar
So its all bolt on I take it?
Old 07-06-2011, 06:54 PM   #65
Yeah bolt on, fuel upgrades,tune and hood
Old 07-09-2011, 08:31 AM   #66
Blackheart4355's Avatar
Texas...not sure why you are so negative on v6 cars...but I will try to dispel some myths you have unknowingly put forward. The tranny in a v6 is not weaker than the one in a 4.6l car. In fact it is actually stronger. The t5 is the one used on 5.0l fox bodies as well as 3.8/3.9l cars. It is a very strong and capable tranny. Even the auto box used on v6 cars is stronger!! Both super six and Tom Morana sell kits to use the m112 on the 3.8/3.9l engine. Now before installing it I would highly recommend building up the bottom end first. The one thing one does have to keep in mind when building up a v6 car is when the time has come to swap out the 7.5 rear end for an 8.8 with t-lok and upgrade the brakes. Some people buy v6 cars because at the time they can't justify the added cost of a v8 car. It may cost a bit more to get a really powerful v6 car, but it can be done for a reasonable cost and if you are on a budget..then you can do a bit at a time. We really should try to help each other out and not slamming a guy for wanting to get the most out of his 6 banger. The toughest part on a v6 build up is getting a good dyno tune. Many shops claim they can tune a v6...few do it well.
Blackheart4355 is offline   Reply With Quote
Old 07-09-2011, 08:38 AM   #67
I'm not negative. I'm honest. The cost to have a v6 that run fast is expensive. Near impossible on stock internals
Old 07-09-2011, 08:39 AM   #68
Texas...not sure why you are so negative on v6 cars...but I will try to dispel some myths you have unknowingly put forward. The tranny in a v6 is not weaker than the one in a 4.6l car. In fact it is actually stronger. The t5 is the one used on 5.0l fox bodies as well as 3.8/3.9l cars. It is a very strong and capable tranny. Ever the auto box used on v6 cars is stronger!!
Um... T5s are know to handle around 350hp tops!
Old 07-09-2011, 08:40 AM   #69
And who gives you the idea they would put stronger parts in the v6s and say screw the v8s they can have the s*** parts???
Old 07-09-2011, 08:51 AM   #70
Hmm..just every publication who has ever tested the v6 car and addressed that specific topic because for some reason it is a misguided belief put out there by v8 owners!
v6 swap to cobra will21 Pre-2005 V6 Mustang 43 09-07-2011 04:56 PM
ordering 12 mustang v6. need opinions SoFlo Mustang 2011-2014 V6 Mustang 17 07-05-2011 08:02 AM
03 v6 upgrades? TaylorF25 Pre-2005 V6 Mustang 11 06-27-2011 10:02 PM
03 v6 rear brakes TaylorF25 Pre-2005 V6 Mustang 8 06-25-2011 10:01 PM
08:00 PM
