best way to lift motor - Mustang Evolution
Old 07-01-2011, 10:19 AM   #1
In order to get to my freeze plug to replace it [the one under the motor mount] I need to raise everything up off the mount and take it off.
I've gotten the nuts off the mounting bolts, so it's just resting there.
What is the easiest, safest, least likely to mess something else up way of raising the engine just enough to get this done?
I've got the car up on jack stands and have been crawling around underneath it, but I'm having a hard time finding any place to put a jack that looks sturdy enough. And from the top...there's stuff everywhere that I'm afraid an engine hoist and chains would break. When I originally put the thing in, all the extras were off and I had big massive bolts to attach the chain to. [In addition, if I can do it from underneath and avoid having to take the hood off...again...that'd be great...though, if not, I'll suck it up.]
Thanks!
shustwit is offline   Reply With Quote
Old 07-01-2011, 10:49 AM   #2
Send a message via Skype™ to Texastboneking
Engine host to the side of the engine your lifting. As long as your not using a cheap chain you should be fine.
Texastboneking is offline   Reply With Quote
Old 07-01-2011, 10:51 AM   #3
Thanks!
A jack on the oil pan can work but cod crush it
And you can leave the hood on with a cherry picker
Old 07-02-2011, 09:00 AM   #4
Re: best way to lift motor
There really wasn't any way to get to the oil pan on my particular car, so I had to lift it from the top. Of course, once I got the cherry picker in place, I had a hard time finding room for me under it
And then my husband said "why don't you just take the wheel off?" Brilliant! Yea, for change of perspective.
Man, those bolts did NOT want to come off, and getting a breaker bar in there was a bit of a trick, but 9 hrs later [and only 2 trips to the parts store,] it's all back together...and I didn't break anything else, which is a miracle in and of itself.
Whew.
Old 07-02-2011, 09:05 AM   #5
Whew.
Forgot you were a female . Very impressive
1989 mustang motor knock kbolden50 1979-1995 Mustang GT 66 09-11-2011 08:10 AM
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
10:40 AM
