looking for reliable lowering springs! - Mustang Evolution
Old 07-05-2011, 01:04 PM   #1
cakedout's Avatar
For a 99 v6..any suggestions?
cakedout is offline   Reply With Quote
Old 07-05-2011, 01:16 PM   #2
kickerofdoom's Avatar
Ford racing spring
Old 07-05-2011, 01:25 PM   #3
Re: looking for reliable lowering springs!
ford racing C springs are great springs, they have a stiff rate so they handle better... but ride worse. You can try to find some B springs for a softer ride.
Old 07-05-2011, 11:49 PM   #4
cakedout's Avatar
Cool thx
Old 07-06-2011, 01:30 AM   #5
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
H&R makes a quality spring also. I'm very happy with mine.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 07-06-2011, 10:27 AM   #6
i love my H&R just a bit more costly than the Ford B Springs, also you may require CC plates, thats 180 bucks for those on top of springs and install.
Old 07-06-2011, 06:21 PM   #7
Yah Eibach Sportline springs and H&R Super Sports are going to require CC plates a bumpsteer kit and possibly new shocks/struts. The drop is significant compared to stock.
If you want a noticeable but not over the top drop look into some Ford Racing springs (B or C's) as said above or possibly Eibach pro kit springs. I've heard of them dropping cars anywhere from 1" to slightly over the advertised 1.5", in which case you'd probably want CC plates to make adjusting your suspension geometry back to spec much easier.
Anytime you lower the car you should get an alignment. I personally would do it regardless of the drop. .75" or 2", it's worth the money to get it done.
Old 07-12-2011, 02:29 PM   #8
cakedout's Avatar
Awesome..yea I think im going to go with the ford racing b's..I dont have the funds for all the other components..thanks tho man!
Old 07-12-2011, 08:02 PM   #9
Cool, you'll be happy with those springs...they will drop the car some but not too much to where daily driving is a hassle.
You may want to consider an alignment after the drop even with the b springs. I'd measure the height from the ground to the fenderwell at stock height, then I'd wait for the car to settle fully ~ week or so, then measure the height to the fender again. The difference in height will tell you how much the car was lowered. If it's around 1.25" or more I'd probably get an alignment. Better to spend $100 on an alignment than several hundred on new front tires.
Thinking about some lowering springs 2002Gt 1996-2004 Mustang GT 68 06-25-2011 11:45 AM
09:39 PM
