general 98 questions - Mustang Evolution
Old 07-07-2011, 04:37 PM   #1
bradh2414's Avatar
Ok I drive a 1998 v6. I have pretty much done nothing to it yet. I bought it with dual exhaust and that's it. I just have some questions performance-wise.
1. I have no mufflers only cats, so does the lack of back pressure take away from my overall performance??
2. I want to do a CAI but my dad thinks the stock looks pretty good. Should I for better performance? And if so what brand should I use and where do I get it?
3. Say I want to do an AC delete since my AC system is absolutely shot ($600+ in repairs). Does this do anything for performance and how hard is it to do?
4. It's a DD mostly around town to work and back. What new gears would be good for nice acceleration but still good for highway and higher speeds?
5. Are there any other pretty cheap mods I can do to improve performance/handling and help my engine run better?
Any answers helpful thanks
bradh2414 is offline   Reply With Quote
Old 07-07-2011, 04:42 PM   #2
bradh2414's Avatar
Btw it's a 5-speed
Old 07-07-2011, 06:10 PM   #3
Re: general 98 questions
1. The low end torque will be affected. You will have a slight increase in HP though.
2. Not much of a gain. Just do a drop in k&n filter and remove silencer.
3. It will free up some HP. Not much at all. Although you're insane to do an a/c delete on a DD.
4. 3.73s are good for a manual
5. A split port swap is your best bet. It will bring you up to 99-04 v6 power which I believe is about 40 HP more.
Do you have a budget. What are your goals?
tigerfan2771 is offline   Reply With Quote
Old 07-07-2011, 09:01 PM   #4
Greg687's Avatar
Region: New Mexico
On topic... what part is the silencer? My 98 has a K&N, but it all looks stock.
To the OP, you could also put in under drive pulleys for a little kick. The V6 will not be a V8, though it can come close with a LOT of $$$. Enjoy it for what it is. Do the gears and a T-loc, maybe lower it a bit and replace any worn suspension parts to improve the handling, then buy a 99 V6 engine from a junk yard and build it up slowly so you can replace it all in one shot. That is my plan anyway
Greg687 is offline   Reply With Quote
Old 07-07-2011, 10:03 PM   #5
Send a message via Skype™ to Texastboneking
Listen to tiger. He's got it down right
Texastboneking is offline   Reply With Quote
Old 07-07-2011, 11:33 PM   #6
bradh2414's Avatar
Thanks. I'm not gonna do the AC delete I was jw. And how hard is it to change the gears?
Old 07-08-2011, 04:42 AM   #7
It is a job for a mechanic. Not very easy. The gears need to be set up perfect or they will go to whining. Gears will run about 150, the tlok will run about 200, the bearings and fluid about 100, and a good install 350+ to give u an idea of the cost
The pulley is good for about 6rwhp across the power band. I did a before and after dyno. Not sure where the sheet went.
You could also do long tube headers with a midpipe. The shorties are an absolute wast on a non supercharged car
Old 07-08-2011, 04:50 AM   #8
It has a k&n filter or intake? The silencer is the black snorkel looking thing that is beside the fenderwell
Old 07-08-2011, 06:49 AM   #9
kickerofdoom's Avatar
You can install a tlock your self and lowering spring. Subframe connector
Old 07-08-2011, 08:03 AM   #10
Id hold off on the subframe connectors on a near stock car.
Old 07-08-2011, 08:44 AM   #11
wereKEV's Avatar
It will never be as pwerful as a v8 but you can still have fun with a 6er.
wereKEV is offline   Reply With Quote
Old 07-08-2011, 10:04 AM   #12
Greg687's Avatar
Region: New Mexico
K&N filter that replaces the stock. Came that way when i bought it. So, if I take the "snorkel" thing off that will help? I does seem restrictive.
Thanks!
Old 07-08-2011, 10:59 AM   #13
Thanks!
Ehh. In theory it does. Wont show up on a dyno. The filter is the main restriction
Old 07-08-2011, 11:01 AM   #14
Greg687's Avatar
Region: New Mexico
So, not much benefit to a real CAI then, right? Other than clean looks.
Old 07-08-2011, 11:01 AM   #15
Especially not as powerful as the almighty 3v. But seriously you can get good power out of your car. With a blower and boltons 300rwhp is pretty easy to get. And with a turbo,350+ is fairly easy
my eforce performance questions black09efgt 2005-2010 Mustang GT 2 06-30-2011 08:15 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
02:01 PM
