Starting Issues - Mustang Evolution
Old 07-14-2011, 10:37 AM   #1
bradh2414's Avatar
Starting Issues
Ok. So I was at work and my car just died after like 10 minutes of me just listening to my radio. So we jumped it and I let it run. Turned it off and nothing. Jumped it again and brought it home. Nothing the next day. Jumped it brought it to mechanic. He charged battery and checked the charging system and it was all good. So I took it home and when I went to start it it died again. So he said to replace the battery and I did. Won't start. Any ideas?
I thought alternator but that's not it. Starter or ignition??
Please help
bradh2414 is offline   Reply With Quote
Old 07-14-2011, 11:00 AM   #2
Jamesgt08's Avatar
Did u get a brand new battery?
Jamesgt08 is offline   Reply With Quote
Old 07-14-2011, 11:20 AM   #3
bradh2414's Avatar
Yeah. It could be the connection so I'm checking if all the cables are tight but I still dunno
Old 07-14-2011, 11:32 AM   #4
Jamesgt08's Avatar
Hmm thats weird if u replaced the battery. Maybe fuses.
Old 07-14-2011, 11:34 AM   #5
skyline247's Avatar
Since you're able to run the car fine after jumping it, I doubt the alternator is the problem. When starting the car, do you hear the starter trying to start the engine, or is it just a single click and nothing else? If it's the latter then it's the battery. Since your mechanic gave you a new battery and checked your charging system, the problem might be the connections to and from the battery. Check to make sure all the wires are on snug, and make sure the battery terminals are clean.
I'll try to think of what else could be the problem, but someone else might be able to chime in with other suggestions.
1988 GT - Stock
*SOLD* 2012 GT Premium, Black on Black, 3.55 Axle, HID and Security Package, Pypes Pype Bomb Axle Backs
skyline247 is offline   Reply With Quote
Old 07-14-2011, 11:57 AM   #6
bradh2414's Avatar
I cleaned the battery connectors. And i'm trying to follow the cables to see where they lead to check them and can't find it. I also can't get the car up high enough to get under it right now.
Old 07-14-2011, 11:57 AM   #7
bradh2414's Avatar
And yeah at first all I heard was a click. Now I get absolutely nothing
Old 07-14-2011, 11:58 AM   #8
kickerofdoom's Avatar
Fuses check them and tighten the connection on the battery
Old 07-14-2011, 11:59 AM   #9
bradh2414's Avatar
As tight as it gets. And which fuse would be starter? Or do I check them all?
Old 07-14-2011, 12:00 PM   #10
Jamesgt08's Avatar
Check em all.
Old 07-14-2011, 12:03 PM   #11
bradh2414's Avatar
Originally Posted by Jamesgt08
Check em all.
Pull em and look right? And in the engine and under the dash? Both sets?
Old 07-14-2011, 12:24 PM   #12
Jamesgt08's Avatar
I would mainly just check under hood. That where all ur starter and main fuses are.
Old 07-14-2011, 12:24 PM   #13
Jamesgt08's Avatar
I use to have a diagram for ur fuses but i cant find it.
Old 07-14-2011, 12:50 PM   #14
skyline247's Avatar
+1
1988 GT - Stock
Old 07-14-2011, 01:46 PM   #15
bradh2414's Avatar
Well a fuse wouldn't just start working if I charge the battery then randomly stop. If I jump it it runs so I doubt it a fuse
Old 07-14-2011, 02:23 PM   #16
Jamesgt08's Avatar
Yes it can be a fuse doing it. It can make the alternator not charge ur battery.
Old 07-14-2011, 02:26 PM   #17
bradh2414's Avatar
But if I jumped it that wouldn't affect it really. It get no juice at all
Old 07-14-2011, 03:35 PM   #18
bradh2414's Avatar
Got it. Off the positive cable it splits to two wires. One to fuses one to everything else. They were loose. Not the connector but it's wires. Tightened it and boom starts
Old 07-14-2011, 03:49 PM   #19
Jamesgt08's Avatar
So the wire to the fuse box was loose?
Old 07-14-2011, 03:55 PM   #20
bradh2414's Avatar
Exactly. Actually where that wire met with the other one it was. But yes
Old 07-14-2011, 06:14 PM   #21
skyline247's Avatar
Glad you got it figured out.
1988 GT - Stock
Old 07-14-2011, 07:19 PM   #22
bradh2414's Avatar
Ya thanks to my dad on that one
Old 07-14-2011, 07:27 PM   #23
Jamesgt08's Avatar
I was close. Lol. I told u to check fuses so u found the loose connection.
Old 07-14-2011, 08:15 PM   #24
bradh2414's Avatar
I didn't find it lol. I was clueless. Electronics and wires kill me
Old 07-14-2011, 08:24 PM   #25
Jamesgt08's Avatar
Oh ok well ur dad found it lol. Wires an connections isnt that hard i play with wires all the time i love installing radios and stuff.
Old 07-14-2011, 08:43 PM   #26
bradh2414's Avatar
Radios I can do. But they aren't too hard. Idk batteries and ignition seem harder
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
Different Starting Problems milkrun49 2011-2014 Mustang GT 3 07-15-2011 02:19 PM
Starting my hunt for my next mustang! sonic04edge General Mustang Discussion 16 07-12-2011 07:03 PM
01 Mustang V6 having issues Mustanglife Pre-2005 V6 Mustang 29 06-25-2011 10:33 AM
03 cobra clutch issues. zinc03 SVT Mustang 4 06-24-2011 12:18 PM
02:20 PM
