Another Issue (overheating) - Mustang Evolution
Old 07-14-2011, 08:51 PM   #1
bradh2414's Avatar
I have a new radiator and it's full of coolant and my resiviour is good too. But when I sat in traffic for 10 minutes today I was at red hot and had to pull over. Any ideas? I was told sticking thermostat.
Ps. My fan doesn't always turn on either but that wouldn't cause this right??
bradh2414 is offline   Reply With Quote
Old 07-14-2011, 09:00 PM   #2
Jamesgt08's Avatar
Yea like i said i would just replace the thermostat its easy and cheap. Most likely ur problem.
Jamesgt08 is offline   Reply With Quote
Old 07-14-2011, 09:19 PM   #3
bradh2414's Avatar
K. Imma fill it of coolant too. Check water pump. And make sure my radiator cap is tight lol
Old 07-15-2011, 08:41 AM   #4
jhagan1980's Avatar
Any air in the hoses can cause you to run hot as well.
jhagan1980 is offline   Reply With Quote
Old 07-15-2011, 08:49 AM   #5
bradh2414's Avatar
How do I fix that?
Old 07-15-2011, 11:19 AM   #6
wereKEV's Avatar
Re: Another Issue (overheating)
The thermostat sounds like it is sticking.
wereKEV is offline   Reply With Quote
Old 07-15-2011, 11:31 AM   #7
Greg687's Avatar
Region: New Mexico
If your fan won't turn on and the temp is high it will continue to get hotter. Only when you are driving and air is pushed through the radiator will the fan not do a whole lot to cool. So, to answer clearly, if your fan isn't turning on, it will cause it to overheat, especially in traffic. Check the fan temp switch, the fan motor and the CCRM, in that order. I'm guessing you had your a/c on as well, which SHOULD make the fan turn on too.
Greg687 is offline   Reply With Quote
Old 07-15-2011, 01:57 PM   #8
check your relay/fuse panel
Old 07-15-2011, 01:58 PM   #9
bradh2414's Avatar
Nope no AC lol. Broken. Ok well I'm changing the thermostat first tomorrow and filling the system. If none of that making sure it isn't my water pump. Then checking the fan
Old 07-23-2011, 12:42 AM   #10
1gt289's Avatar
It's most likely to be the thermostat it happened to my dad changed it and worked just fine
1gt289 is offline   Reply With Quote
Old 07-23-2011, 10:55 AM   #11
Blackheart4355's Avatar
I'd definitely check the switch on the fan. If the fan isn't coming on, you've got big problems. Oh and make sure the engine is cool before you open the cap...I know that sounds like I'm talking down to you but you'd be surprised the number of people who open it when the engine is still hot!
Blackheart4355 is offline   Reply With Quote
Old 07-23-2011, 10:56 AM   #12
bradh2414's Avatar
I'm not that clueless lol. Got that. And I think I'm just gonna wire the fan to stay on instead of replacing the CCRM and everything if it comes to that.
Old 07-23-2011, 10:59 AM   #13
Sorry..but you'd be surprised at the number of people who get burned by hot coolant. I would refrain from wiring the fan to stay on. The new switch is usually not very expensive and is not then a constant draw on your electrical system.
Old 07-23-2011, 11:03 AM   #14
bradh2414's Avatar
How hard is it to replace all of it?
Old 07-23-2011, 11:13 AM   #15
Wire it to under your dash so you can flick it on
16218 is offline   Reply With Quote
Old 07-23-2011, 11:58 AM   #16
1gt289's Avatar
Shouldn't be too hard just find the wires that go the fan and trace em back
Old 07-24-2011, 11:33 AM   #17
TaylorF25's Avatar
I had the exact same problem with my 03 v6 and everyone told me it was the thermostat. My fan would only come on if I moved it a little it would kick on. It was my fan that was causing it to overheat. It was an aftermarket fan and was to small for the car, I replaced it was a stock fan and it works perfectly.
TaylorF25 is offline   Reply With Quote
Old 07-27-2011, 01:21 AM   #18
I just had the same problem with my stang turns out it was the fan motor just replaced it now it runs great no overheating.
96stangvert is offline   Reply With Quote
Old 07-27-2011, 03:19 PM   #19
Ya could be the fan motor..but I'm guessing it's the switch.
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 09:06 PM
04:34 PM
