Alternator? - Mustang Evolution
Old 07-16-2011, 04:28 PM   #1
bradh2414's Avatar
Alternator?
Ok. I had an isse last week with my car not starting because two wires to the battery were loose. Fixed em but now whenever I drive my battery light seems to still stay on.
Is it a bad alternator or is it different wires or what?
bradh2414 is offline   Reply With Quote
Old 07-16-2011, 06:21 PM   #2
Qwik Four Six's Avatar
Most likely an alternator.. Might want to pick up a tester at a parts store. They're not much and you can check the battery with the car off and you can check the alternator by hooking the red to the positive and the black to the negative while it's running. I'll see if I can find a link and show you...or I could do a quick video..?
Qwik Four Six is offline   Reply With Quote
Old 07-16-2011, 09:13 PM   #3
bradh2414's Avatar
Thanks man. I tested it an saw it wasn't charging. So I followed the wires and found out they were loose. Tightened them up and reconnected the alternator and the light came off
Old 07-16-2011, 10:52 PM   #4
That's good. How about that new thermostat?
Old 07-17-2011, 08:30 AM   #5
bradh2414's Avatar
Good. Took longer than expected. It also made me realize that I might not have a 98 engine. The auto yard said itcwas but now it's iffy
Old 07-17-2011, 09:43 AM   #6
Ohhh. Dang.
Old 07-17-2011, 09:52 AM   #7
bradh2414's Avatar
Ohhh. Dang.
Yeah the older newer engines have an oring seal the thermostat housing but this still had a paper gasket
Old 07-17-2011, 10:32 AM   #8
Oh. Well as long as it runs good.
Old 07-17-2011, 01:31 PM   #9
bradh2414's Avatar
Exactly.
Old 07-17-2011, 01:52 PM   #10
goherd's Avatar
Exactly.
I have already replaced mine. Only have 33,000 and change on the engine
goherd is offline   Reply With Quote
Old 07-17-2011, 10:00 PM   #11
bradh2414's Avatar
Well i think it's good now. I won't be upset if it does go now since i'm kinda expecting it
02:33 PM
