Low end Torque V6 - Mustang Evolution
Old 07-17-2011, 02:31 PM   #1
Low end Torque V6
I was wondering if there is a way to get ALOT of low end torque out of a 2002 3.8 V6 without doing any internal engine mods and headers. I currently Autocross my car with my dad who drives a 65 Shelby Cobra. I'm so hell bent on beating him but currently my Stage 1, 2, and 3 Steed suspension and Steeda Cold Air intake isn't giving me enough "UMF" to beat him. I'm about 4 seconds behind him, And god I'm Hell bent to beat him in MY CAR! or maybe beat him in his own car.... Any help would be great keep in mind im 16 with a minimum wage busser job.
ewatts is offline   Reply With Quote
Old 07-17-2011, 03:01 PM   #2
Greg687's Avatar
Region: New Mexico
Lower gears maybe?
Greg687 is offline   Reply With Quote
Old 07-17-2011, 03:46 PM   #3
Titus Wadicus
svtlx's Avatar
Re: Low end Torque V6
it's blower time!!!
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-17-2011, 06:26 PM   #4
Yah a power adder with low boost and solid tuning is probably the best way to gain the most torque without tearing into the engine.
There aren't many other ways to gain serious torque. As said, gears will better distribute the torque throughout the power curve...an aggressive tune on a higher octane might also wake the car up a bit. The timing and a/f ratios being altered boosts the car's response significantly.
Old 07-17-2011, 08:01 PM   #5
Chris01's Avatar
Easy upgrade since its on top of the engine..
http://www.vapauto.com/windstar.htm
Chris01 is offline   Reply With Quote
Old 07-17-2011, 09:57 PM   #6
Blackheart4355's Avatar
This is a great upgrade..but doesn't do much for torque...I love it on mine...
Blackheart4355 is offline   Reply With Quote
Old 07-17-2011, 10:16 PM   #7
Jamesgt08's Avatar
That looks cool. Almost looks like the new 5.0 lol minus 2 more cylinders.
Jamesgt08 is offline   Reply With Quote
Old 07-17-2011, 10:57 PM   #8
Chris01's Avatar
They say u will gain 15 ft/lbs so u will get something out the deal and it's also half the weight of the stock intake better for autocross
Old 07-17-2011, 11:00 PM   #9
Chris01's Avatar
U also said headers but u can keep them and and just get some type of exhaust to let the engine breath better
Old 07-18-2011, 07:13 AM   #10
not much you can do other than gears~ but that comes at the price of higher rpms up top~ so its a trade off.
Old 07-18-2011, 09:17 AM   #11
Titus Wadicus
svtlx's Avatar
maybe a 3.55 gear would be good. better low end torque, and let him get a taste of v-8 fuel milage.
Old 07-18-2011, 09:38 PM   #12
I have yet to see 3.55's for the 7.5" in the v6's. There might be some out there for the 7.5" that were in the fox bodies a while back.
If not he'd have to get an 8.8" rear and upgrade the gears.
Old 07-19-2011, 10:57 AM   #13
Titus Wadicus
svtlx's Avatar
he could even get a 3.73 out of a ranger
Old 07-19-2011, 11:15 AM   #14
weight reduction would be the next thing, you can shave down the V6 to crazy levels compared to the GT as well as look into rotating weight (wheels, drive shaft) those add up 1lb of dead weight = 10lbs of rotating weight~
Old 07-21-2011, 12:43 AM   #15
austinknoll's Avatar
Why different than the gt? Besides a smaller engine, how else would you make it lighter? I've always wante to to that
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-21-2011, 01:19 AM   #16
Las0mbra's Avatar
Well, the big thing is the engine... The gt is very nose heavy in the corners..
Old 07-21-2011, 03:45 PM   #17
I have changed the gears a little bit by putting in a Mach 1 axle and this winter I am putting in the world class transmission my dad has in his Cobra since he is running to much horse power through his but I guess weight reduction would be the next thing
Old 07-22-2011, 07:21 AM   #18
the engine is lighter, so is the T-5 vs the T-45 the GT has. The base V6 is 3060lbs~ most average around 3100-3150 with a manual transmission.
Cut weight and get light wheels and you can make a big difference for sure.
2011 front end noise question. Help please drivinglesson 2011-2014 Mustang GT 15 08-31-2011 01:38 PM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
08:16 AM
