Why does the a/c effect my car - Mustang Evolution
Old 07-21-2011, 01:39 AM   #1
1gt289's Avatar
I have a 96 v6 mustang, when I turn on my a/c my car becomes sooo sluggish and slow and chugs gas, it jerks a lot between shifts and especially getting into first gear, I don't know why this happens but I don't like it if there was a way to fix these could someone please tell me!? The car is basically stock. It's about 100 degrees outside and not turning on the ac dosnt sound too reasonable
1gt289 is offline   Reply With Quote
Old 07-21-2011, 06:30 AM   #2
Tib
Tib's Avatar
Re: Why does the a/c effect my car
when you turn the ac on, the engine now has to drive the compressor which is more resistance on the system. It's normal. That's why you'll see some people delete the ac system and put a ac delete pulley in it's place.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 07-21-2011, 07:39 AM   #3
illestdomer2005's Avatar
To me, going fast isn't worth cooking!
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 07-21-2011, 08:03 AM   #4
Greg687's Avatar
Region: New Mexico
It will use some power, but It shouldn't bog the car down. Either there is something wrong with the a/c causing too much drag on the engine, or your car needs a tune-up. My 98 barely notices it when I turn the ac on.
I've seen a/c that were overcharged that would do this. I would start by checking that first.
Greg687 is offline   Reply With Quote
Old 07-21-2011, 11:02 AM   #5
1gt289's Avatar
I would do this but I'm not the only one that drives my car my dad uses it a lot and if I mentioned deleting the ac he'd prolly kick me in the butt lol
Old 07-21-2011, 11:08 AM   #6
1gt289's Avatar
When I use my ac it sorta does bog the car down I mean why would I need a tune up tho my car is basically stock under the hood and ive never messed with the ac system I'll check and see if it's overcharged but I've had my car for 2 years the first year I had it for 5 to 6 months and some dumb lady ran a red light and t- boned me I had Liability insurance so I was stuck with the repairs, 7 months later she was back on the road again idk if this could have effected it I never remember how it was before the crash cus I bought it in winter and never used the ac back then
Old 07-21-2011, 11:25 AM   #7
I can notice for sure when my AC is on same with my old 01 V6 but its not a horrible thing, idle can suck at times though
Old 07-21-2011, 12:23 PM   #8
1gt289's Avatar
I think mine eats too much power that's why I don't think it's normal, there has to be someway to fix it maybe?
Old 07-21-2011, 06:50 PM   #9
junoS197Bl08's Avatar
When I'm idling sometimes I will notice the engine shake a little every now and again but only when I'm running the A/C, does anybody else have this issue? b/c I've never noticed this on a car before.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 07-21-2011, 06:51 PM   #10
Las0mbra's Avatar
Mine does that every once in a while.
Old 07-21-2011, 07:45 PM   #11
bobbytheapple's Avatar
Maybe you could just grab a cold air intake to balance the difference.
When I turn on my AC, I can hear mine suck in more air.
Just a thought.
This should fit yours http://www.americanmuscle.com/94-98-...ir-intake.html
Maybe you can find one on eBay for less.
bobbytheapple is offline   Reply With Quote
Old 07-21-2011, 09:17 PM   #12
I would say it's normal...keep in mind your car is 15 years old, so the A/C system may be worn and working harder. My car runs harder when the A/C's on as well...I too have a CAI and you can hear when the engine is working harder, especially at idle. It's normal to use more gas when the A/C's on...this in addition to radios and power options takes power away from the car causing a slight decrease in performance and more fuel consumption.
It is possible the unit's overcharged...it's possible something might have happened after your accident and repairs. I'd start there...
Old 07-21-2011, 10:32 PM   #13
1gt289's Avatar
Mine does the same thing
Old 07-21-2011, 10:35 PM   #14
1gt289's Avatar
Yea I'm going to check it tomorrow to see if it's overcharged and do you think a cai would help me out? Like I Saudis eats more gas but I can smell it inside the car, I doubt that's normal, but it may just be me
Old 07-21-2011, 10:52 PM   #15
Greg687's Avatar
Region: New Mexico
You shouldnt smell gas inside your car. Bad.
You need a tune up periodically because stuff wears out. If you've never done one on this car, you don't know the maintenance history. Lots of reasons to tune it up...
Old 07-21-2011, 10:58 PM   #16
1gt289's Avatar
It's got new oil, oil filter, spark plugs, wires, battery, air filter, it's not a strong scent of gas it's slight but just enough to be noticeable, only with the ac on tho
Old 07-22-2011, 08:08 AM   #17
Hmm...a gas smell sounds a little more serious that just slowing the car down. Not sure that a CIA would help that but it would help some with the power issue. I'd check the compressor pulleys and stuff like that while your at it.
Good luck.
Old 07-22-2011, 01:08 PM   #18
1gt289's Avatar
Good luck.
Thanks the gas smell use to be quite strong but over time it's not really noticeable only occasionally,I might get a cai to se if I get some power back at least, any other mods I can do to help?
Old 07-22-2011, 03:35 PM   #19
Tune. That'll cost you more but it'll let let you get the most out of your cai while adding it's own upgrades and power. Free tunes from BAMA will beef up your car a bit. I suggest this: SCT SF3/X3 Power Flash Tuner w/ 3 Free Custom Tunes (96-98 V6) at AmericanMuscle.com - Free Shipping!
Old 07-22-2011, 10:02 PM   #20
Blackheart4355's Avatar
Do a tune up...if it's still running rough after that I'd say it's the compressor..the clutch is probably going....
Blackheart4355 is offline   Reply With Quote
Old 07-23-2011, 01:21 AM   #21
1gt289's Avatar
It got a tune up not too long ago, and my clutch grabs great, the clutch is good it might be the compressor I'll check it out
Old 07-23-2011, 07:47 AM   #22
Greg687's Avatar
Region: New Mexico
He means the clutch on the ac compressor
Old 07-23-2011, 12:55 PM   #23
1gt289's Avatar
O ok I'll look into it
Favorite Thing About Your Car Thread bradh2414 General Mustang Discussion 43 07-24-2011 05:55 PM
-1984 a/c 16218 1979-1995 Mustang GT 9 07-21-2011 12:21 PM
My car is hurt :( GoldenPonyBoy 2005-2010 V6 Mustang 25 07-19-2011 11:11 PM
Car Covers! Murdered_Stang General Mustang Discussion 8 06-26-2011 04:03 PM
09:09 AM
