302 5.0 v8 from a 95 f150 into a 95 mustang 3.8 v6 - Mustang Evolution
Old 07-23-2011, 04:32 PM   #1
it might sound stupid but i have a 5.0l from a f150 i was just wondering would i fit my mustang that currently has a v6 3.8 even with mild modification?
Pascullon is offline   Reply With Quote
Old 07-23-2011, 05:32 PM   #2
Blackheart4355's Avatar
Yes it will fit, however you will need a k member from a 94 or 95 GT as well as the computer...harness...and probably a few other things...
Blackheart4355 is offline   Reply With Quote
Old 07-23-2011, 05:50 PM   #3
Re: 302 5.0 v8 from a 95 f150 into a 95 mustang 3.8 v6
how do i find out what other things?
Old 07-23-2011, 06:02 PM   #4
Well I'm sure those who have done the swap will jump in....
Old 07-26-2011, 09:18 PM   #5
Titus Wadicus
svtlx's Avatar
u wont need a k member, it will drop right in
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-27-2011, 03:10 PM   #6
So I won't need other parts?
Old 07-27-2011, 03:12 PM   #7
Uhm..I've always been told the V6 and V8 K members are different. ESP due to the engine mounts....
Old 07-28-2011, 09:51 AM   #8
Titus Wadicus
svtlx's Avatar
they are different if you use a 4.6 mod motor. pushrod v8 (i.e. 302/351) is the same mounts as 3.8 v6.... they also share the same bell. you can use the auto trranny if u have one, but if it's a 5spd u will need to get a 87-95 v8 bell housing cause the starter is in a different slightly different location.
u will have to decide wut to do with the intake. you can try to make the f150 intake work (i wouldnt do it), use a fox body intake set-up, or use an sn95 body set-up.
check out "its alive" thread in 79-95 forum. i uploaded sum pics of 96 v6-v8 conversion
Old 07-28-2011, 11:26 AM   #9
So the fox body intake from a 95 fox will go right in? So I can use my auto tranny and it will work thats awesome
Old 07-28-2011, 11:39 AM   #10
Titus Wadicus
svtlx's Avatar
u will have have to change throttle cable... and the cruise as well if you are planning on using it.
u can hard wire in the computer and harness from the f150. your gonna need a stang book and a f150 book to match up the wires. your easier bet is to use a 94-95 5.0 harness cause its 98% plug and play.
you can p.m. me and i will give u my number... its alot to explain on here.
Old 07-28-2011, 01:02 PM   #11
stampde's Avatar
also engine mounts from a fox and oil pan and oil pump pick up will need to be changed , and of coarse exhaust manifolds or headers
2011 GT Auto
Old 07-28-2011, 03:19 PM   #12
If so then why is the 94-95 k member different than the V6? 94-95 had the 302 in it....
Old 07-28-2011, 11:06 PM   #13
Titus Wadicus
svtlx's Avatar
94-04 v6..and 94-95v8 have the same k-member.
96-04 v8 uses a different k-member
1999 mustang v6 cat back C4king Pre-2005 V6 Mustang 8 07-29-2011 09:33 AM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
06:45 AM
