1995 Mustang, need help! ): - Mustang Evolution
Old 07-23-2011, 11:58 PM   #1
austinray4142's Avatar
I have a 3.8L v6 mustang, its having a problem and I need help to fix it :/ . I drive my car to empty so I would get all the bad gas out of it... I know, stupid thing to do. But I filled her up with 93. Now she doesn't want to run, it stalls when I tap the gas, floor the gas or try to rev... But when idling works fine. I replaced the plugs, wires, clean my coldair filter, and replaced the fuel filter... And still not better.
Can ANYBODY help me pleeeeeeease :/
austinray4142 is offline   Reply With Quote
Old 07-24-2011, 12:04 AM   #2
bradh2414's Avatar
Well it's probably not the best idea to switch gasoline types this late.
bradh2414 is offline   Reply With Quote
Old 07-24-2011, 12:07 AM   #3
Jamesgt08's Avatar
Maybe ur injectors are clogged.
Jamesgt08 is offline   Reply With Quote
Old 07-24-2011, 12:08 AM   #4
Jamesgt08's Avatar
Go get a can of sea foam and put like half in ur tank will clean ur fuel sytem. I love that stuff i use it on my car.
Old 07-24-2011, 12:09 AM   #5
Re: 1995 Mustang, need help! ):
Fuel pump?
Old 07-24-2011, 06:46 AM   #6
Fuel pump?
I have replaced the fuel pump, and it's got
Sea foam all in the system. Still won't work .
Old 07-24-2011, 08:07 AM   #7
Blackheart4355's Avatar
I'd check for spark....perhaps a bad coil pack ....or maybe the alternator is crapping out under load.....
Blackheart4355 is offline   Reply With Quote
Old 07-24-2011, 08:45 AM   #8
It might be the coil pack.. cuz I just replaced the alternator maybe 3-5 months ago?
Old 07-24-2011, 08:54 AM   #9
Gster's Avatar
If you let it run completely out of gas it's more than likely your fuel pump. Dosn't matter if you had replaced it before. When you run out of gas there is nothing left to cool your fuel pump so it burn up.
Gster is offline   Reply With Quote
Old 07-24-2011, 09:04 AM   #10
kickerofdoom's Avatar
First off don't use 93 unless your tuned for it. Second running empty will kill your fuel pump. Third just because you changed something doesn't solve the problem if what you changed wasn't the problem it only covers it up
Old 07-24-2011, 09:26 AM   #11
I didnt say just because I replaced it before means that's not it. I'm just hoping thats not it. Don't feel like dealing with that again.
Old 07-24-2011, 09:34 AM   #12
Well its tough to figure out cause you done so much
Old 07-24-2011, 09:54 AM   #13
It sounds like either clogged injectors or a major vacuum leak for the injectors go to napa auto parts and ask for fuel injector rebuild kits and to check for a vac leak spray carb cleaner behind the upper intake and if it picks up you know that's the problem and also fill up with midgrade fuel
Pascullon is offline   Reply With Quote
Old 07-24-2011, 10:22 AM   #14
I do have a vacuum leak which I've had for a couple months now. Didn't think anything of it, it's gotten worse I'll look into that. Thank you!
Old 07-24-2011, 12:24 PM   #15
Titus Wadicus
svtlx's Avatar
exactly wut i was thinking...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-25-2011, 07:55 AM   #16
Come back and tell what the problem was too
Old 07-25-2011, 12:57 PM   #17
I'll let y'all know what was wrong.
Old 07-25-2011, 07:26 PM   #18
Just to let everyone know, I cleaned my MAF, throttle body and Coil Pack, and what do you know... She runs <3 so i know that doesn't mean what ever was wrong is fixed but it buys me more time to save up money.
Old 07-27-2011, 03:11 PM   #19
Hopefully she stats like that too congrats
Old 07-27-2011, 03:13 PM   #20
She's already running weird again. Problems not fixed completely but, I need to fix it for sure!
Old 07-27-2011, 03:15 PM   #21
I'll stick with my original thought...new coil pack is needed....
Old 07-27-2011, 03:15 PM   #22
I believe what I told you will do the trick I had close to the same problem too
Old 07-28-2011, 10:28 AM   #23
Yeah I'm gonna replace the coil pack next pay check, and I might as well talbot to napa. Thank you everyone.
1995 mustang
CPO Mustang 2010 GT Premium ??? wickerman 2011-2014 Mustang GT 14 07-11-2011 10:57 PM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
12:23 PM
