Plethora of Questions - Mustang Evolution
Old 07-24-2011, 11:38 AM   #1
bradh2414's Avatar
1998 3.8L V6
1. I have a tap on my front drivers side brakes. It's not a squeal but like a "tick tick tick" when I drive an louder when I brake. Do I need new pads or should I use wd40 to grease an quiet it?
2. Stupid question: what's engine braking? Is it downshifting an slowing yorself down that way?
3. Double clutching? Useless right?
bradh2414 is offline   Reply With Quote
Old 07-24-2011, 01:11 PM   #2
Las0mbra's Avatar
Originally Posted by bradh2414
1998 3.8L V6
I can answer 2 & 3.
1. One thing, don't use wd-40 on your pads. It'll make your brakes useless for a while...
2. You are correct, it's downshifting to increase the revs to slow you down. Apparently it's way better than using your brakes... I think it's kind of stupid because pads are cheap, if you shift and overrev, a new engine is expensive.
3. Yes. Completely useless in any newer car. The reason you double clutch is if you downshift and you don't have synchros... All newer transmissions have them.(including yours)
Old 07-24-2011, 02:14 PM   #3
Blackheart4355's Avatar
Sounds like perhaps bearings in the front hubs....
Blackheart4355 is offline   Reply With Quote
Old 07-24-2011, 02:44 PM   #4
bradh2414's Avatar
Originally Posted by Las0mbra
I can answer 2 & 3.
Thanks. And I've been told engine braking is bad for your engine. I don't see why. I've never come close to overrevving
Old 07-24-2011, 09:15 PM   #5
Blogger
99ford's Avatar
Re: Plethora of Questions
Yes.. The only time I've down shifted is when I need to brake rather quick and there has been ice on the road and if I apply brakes on ice all hell would brake loose.
In Georgia- salting the roads before ice comes doesn't make sense. Right?
What does make sense, is making sure all the trucks are idling and drivers are sleeping in the idling trucks for when the road may become impassable.
Edit the tick tick tick sound does it go away when the brake pedal is pressed?
If yes then you need pads. Make sure to machine rotors, or replace as well. I have the HAWK HPS pads which are pretty good. Go Ford Genuine Rotors. Motorcraft is okay not impressed.
Old 07-24-2011, 09:20 PM   #6
Blogger
99ford's Avatar
^If sound only happens during braking then I lean towards Hubs.
Old 07-24-2011, 09:23 PM   #7
bradh2414's Avatar
So I'm not supposed to downshift to stop? Just neutral to brakes? Seems silly.
And no it taps when I drive and gets louder kind of when touching my brakes and pretty quiet when onnn my brakes
Old 07-25-2011, 08:31 AM   #8
Blogger
99ford's Avatar
Well you have a manual so you can probably down shift w/o harm as long as you don't drop too low too fast. I thought you might have had an auto. If you have an automatic don't.
That's unsafe to shift to neutral and brake, it can casue the car to go too fast and increase the chance of an accident.
I bet its the brakes.. I'd try that first. I always try the cheaper solution first. And hope that fixes it.
Old 07-25-2011, 08:44 AM   #9
bradh2414's Avatar
Oh yeah a manual. Ok good cause I downshift all the time.
And it I replace pads I go both front not just one right?
Old 07-25-2011, 09:46 AM   #10
illestdomer2005's Avatar
In my manual Honda, I will down**** to brake if I'm heading down a steep'ish hill towards a red light. Other times, I just leave it in whatever gear I was cruising in and maybe ome gear change before popping the clutch in or putting the car in neutral at a light.
People will tell you never cruise in neutral because you might need to accelerate out of a dangerous scenario. I just try to roughly shift to the right gear as I am letting the brakes do the braking
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 07-25-2011, 02:39 PM   #11
bradh2414's Avatar
But downshifting isn't bad? I don't see why it is if you shift smooth. It's just like cruisin high in the powerband
Old 07-25-2011, 11:34 PM   #12
I'm no expert, but I think you'd be hardpressed to overrev in most any normal situation. Hell, I couldn't shift into 1st at high speed even if I tried!
If anything, it feels like it would be harder on your transmission, and that, too, is more expensive than brake pads
Old 07-26-2011, 08:42 PM   #13
austinknoll's Avatar
I did it once. I was dumb and racing my friend home from school so I was at the top of 3rd gear (I have a standard) and I went to go into 4th but accidentaly went into 2nd and my car just went crazy I was all over the road and I immediatly pushedthe clutch in. That saved me. I was stupid don't ever do that kids
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-26-2011, 09:48 PM   #14
bradh2414's Avatar
I've been in 5th and down shifted into 2nd on accident before, but luckily I was going like 50 in 5th so my 2nd could handle it
Old 07-27-2011, 11:10 AM   #15
Blogger
99ford's Avatar
Yes both front need to be replaced.
Old 07-27-2011, 11:33 AM   #16
bradh2414's Avatar
Just double checking. I'll look into it tomorrow when I pull the wheel off. Gotta clean everything anyways. Going to a show kinda
Old 07-27-2011, 03:18 PM   #17
Uhm...by the sounds of things you are not too automotively inclined, but I may be wrong...if you aren't then I'd get it done professionally.
Old 07-27-2011, 03:26 PM   #18
bradh2414's Avatar
No my dad helps me. I can do alot but brakes is where I get uncomfortable. He'll help me
Old 07-27-2011, 03:42 PM   #19
Ok...well you'll need a c clamp, some new brake fluid,,make sure you get the correct kind for your car. Get your new pads and new disks as they are really not much mote expensive that getting the old ones turned.
Old 07-27-2011, 10:14 PM   #20
bradh2414's Avatar
Best place to buy pads? Like autozone
Old 07-27-2011, 10:19 PM   #21
kickerofdoom's Avatar
EBay is nice for brake kits
Old 07-27-2011, 10:25 PM   #22
bradh2414's Avatar
Oh sweet. Thanks
Old 08-02-2011, 10:53 PM   #23
Blogger
99ford's Avatar
Yup bought new calipers on ebay.and got a great deal.
Old 08-03-2011, 01:18 PM   #24
Rascal's Avatar
your replacing the front might as well do the rear too, remember the back calipers are screw in
Rascal is offline   Reply With Quote
Nitrous Questions Murdered_Stang 2005-2010 Mustang GT 2 07-19-2011 12:00 AM
engine swap questions wss003 1979-1995 Mustang GT 2 07-18-2011 11:36 AM
general 98 questions bradh2414 Pre-2005 V6 Mustang 14 07-08-2011 11:01 AM
my eforce performance questions black09efgt 2005-2010 Mustang GT 2 06-30-2011 08:15 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
08:54 AM
