Why are my front wheels heating up so much? - Mustang Evolution
Old 07-28-2011, 03:58 PM   #1
Region: Nevada
It doesnt seam normal.
Carlos92 is offline   Reply With Quote
Old 07-28-2011, 04:59 PM   #2
Blackheart4355's Avatar
Probably need to replace the bearings in the front hubs
Blackheart4355 is offline   Reply With Quote
Old 07-28-2011, 05:14 PM   #3
Region: Nevada
You think it'll give it a lil better performance
Old 07-28-2011, 05:33 PM   #4
Well...if it is the hub bearings that are shot then once replaced the front wheels will spin freely...
Old 07-28-2011, 06:27 PM   #5
Region: Nevada
Ima have to get that fixed soon.
Old 07-28-2011, 06:27 PM   #6
Region: Nevada
Has that happened to your stang?
Old 07-28-2011, 06:38 PM   #7
Project Pony's Avatar
Re: Why are my front wheels heating up so much?
Check your bearings, and it wouldn't hurt to make sure your pads are not dragging, could be a bad caliper.
[SIGPIC][/SIGPIC]
Old 07-28-2011, 07:36 PM   #8
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
How many miles do you have on your car?? If it has less then 80,000 your bearings may be wearing out prematurely. Are they squeaking at all? Another way you can tell is jacking up the car pulling on the front and back behind the tire to feel if their is movement. Compare that to a known good wheel to know how much movement u should have other then that try to locate the source of the heat. Whether it is the break caliber or if the hub itself is hotter. If come to find out the bearing is worn out don't go cheap on the bearings most of those are friction fit and require a special slide tool to yank them out so the better quality you get the less u will have to deal with that crap. If it is your caliper you should feel the heat greater on the caliper then the hub.
gregtommy is offline   Reply With Quote
Old 07-28-2011, 10:42 PM   #9
Region: Nevada
Ima try to do that in the morning! Thanks for the advice btw
Old 07-28-2011, 10:43 PM   #10
um. clarification needed here. we talking rims or actual tires?
IamtheMAN is offline   Reply With Quote
Old 07-28-2011, 10:45 PM   #11
gregtommy's Avatar
good point because if it is only tires they could just be under inflated
Old 07-28-2011, 10:46 PM   #12
Region: Nevada
I'm talking bout the rim and the tire mostly the rim though. For example when I park after driving it the rim feels super hot so does the tire but just not as much as the rim you know what I mean
Old 07-28-2011, 10:46 PM   #13
gregtommy's Avatar
your welcome hope you find your answer
Old 07-28-2011, 10:48 PM   #14
correct. or a bad toe angle in the alignment.
why did everyone start saying bearings??? thats the least probable thing.
if it was a bearing that was getting hot enough to tell then 1) your lucky your wheel hasnt fallen off, and 2) you wouldnt be able to hear yourself think.
most probable cause is break calipers hanging. or... its perfectly normal and your just worrying yourself
Old 07-28-2011, 10:50 PM   #15
gregtommy's Avatar
good point I haven't had a bearing go out in years *knock on wood*
Old 07-28-2011, 10:51 PM   #16
Region: Nevada
If it was to be the break callipers hanging wouldn't that also cause like some sort of noise?
Old 07-28-2011, 10:51 PM   #17
these newer cars bearings easily last over 200,000 miles
Old 07-28-2011, 10:53 PM   #18
not necessarily.
think about it. when you press the brakes it doesn't make a noise. why would it make a noise if it was hanging?
Old 07-28-2011, 10:57 PM   #19
gregtommy's Avatar
well that is easy to figure out all you have to do is jack up the car and turn the wheel see if its hard to turn
Old 07-28-2011, 10:57 PM   #20
Region: Nevada
not necessarily.
Ima try and get this problem fixed soon
What problems can this cause if I leave it like that?
Old 07-28-2011, 11:01 PM   #21
that and usually the rotor looks like this if its locking up http://img.photobucket.com/albums/v2...otorpwnage.jpg
Old 07-28-2011, 11:01 PM   #22
gregtommy's Avatar
well your gas mileage would go down u may have a slight pull to the left on your steering wheel and uneven break pad wear but those are all drastic pad hanging situations and you probably would have noticed it other ways then through your wheel getting hot
Old 07-28-2011, 11:02 PM   #23
Region: Nevada
What would be other ways of noticing the problem? Thanks for the info!
Old 07-28-2011, 11:18 PM   #24
gregtommy's Avatar
jack it up and check it out compare your rotors to what IamTheMan posted as the hyperlink with that data u should be able to see and compare your calipers to see if one sides pads are more worn down then the other thats a sign of rubbing on one side and not the other being fine
Old 07-28-2011, 11:22 PM   #25
Region: Nevada
I'll take that advice. I never really noticed how hot they would get til like just yesterday when I was changing the rim. I couldn't even grip the rim cause of how hot it was
Old 07-28-2011, 11:31 PM   #26
thats normal. they got hot enough that you cant touch them.
Old 07-28-2011, 11:59 PM   #27
Region: Nevada
Yeah
Old 07-29-2011, 12:01 AM   #28
Las0mbra's Avatar
I mean... You have to remember something else too. Your brake rotors get really hot, and they're touching the back of your rims. Your brake rotors get ridiculously hot if you drive aggressively a lot. They're gonna transfer a lot of heat. And it's summer, so that just adds to it.
Old 07-29-2011, 12:05 AM   #29
Region: Nevada
Yeah I was thinking the same too but ima check it out in the morning to be sure too maybe if I drive it around when it's still cool I'll see a difference
Old 07-29-2011, 12:06 AM   #30
Las0mbra's Avatar
Yeah, I mean, I would still check the brakes and that stuff too. I'm just saying it could possibly be normal.
Old 07-29-2011, 01:02 AM   #31
austinknoll's Avatar
I since were talkin about wheels and brakes, I had a question. When I take off my wheels, it's harder to turn the rotor. (both sides) Also my car will shake sometimes when braking at high speeds.
Could it be a warped rotor or bad calipers?or even bad pads cause idk
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-29-2011, 01:15 AM   #32
Las0mbra's Avatar
I can just answer the first question... You have less leverage... The wheel gives you more.
Old 07-29-2011, 06:51 AM   #33
gregtommy's Avatar
As for the second question the shaking could be one of two things with the brakes, in even pads or a warped disk disk most likely. Before you run n get new ones though you can take them in to get turned down just take them to a shop. Last time I had them done it was about 50 bucks for tep
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
Old 07-29-2011, 07:31 AM   #34
I just had my rotors turned two weeks ago at o' rieleys for 32 bucks for all four. I bought new pads as well. I had shaking while braking becuase the rotors were warping, now she brakes smooth as can be.
[SIGPIC][/SIGPIC]
Old 07-29-2011, 09:35 AM   #35
Once my pads run out (they're going to soon) I will do that
65 Mustang coupe
Stock or Aftermarket Wheels? 559Danny Mustang Wheels & Tires 22 08-16-2011 06:36 PM
Powder coat wheels/ buy new rims STONE47 General Car Discussion 8 08-02-2011 12:55 AM
Opinion? Which wheels look better? salcruz Pictures and Videos 15 07-22-2011 10:09 AM
Help a Ford SVTF Owner win some wheels! Black95GT The Bar 0 07-12-2011 11:24 AM
10:35 AM
