Starts...then, won't start - Mustang Evolution
Old 07-29-2011, 07:49 AM   #1
I finally got it started. It ran for a 10 minutes. But when I turned it off and tried to turn it back on, it wouldn't start.
Left it alone with the battery unplugged for several days. Reattached the airfilter pieces thinking that might be a problem. It Started! Yea!
Turned it off after a few minutes. Now it won't start.
Anyone had this happen? I don't know if it's a computer issue, or what.
Thanks,
Sarah
shustwit is offline   Reply With Quote
Old 07-29-2011, 07:56 AM   #2
Project Pony's Avatar
Re: Starts...then, won't start
When it doesn't start does it click, or is it trying to turn over?
[SIGPIC][/SIGPIC]
Old 07-29-2011, 11:30 AM   #3
It tries to turn over. Just replaced the starter.
We thought it was a gas issue and tested the gas pressure, but that seems close enough to normal.
Old 07-29-2011, 12:07 PM   #4
Jamesgt08's Avatar
When that happened to me. My fuel pump went out. It always tried to turn over but never did and i got it started one time then it died and i changed the pump and works perfect.
Jamesgt08 is offline   Reply With Quote
Old 07-29-2011, 12:46 PM   #5
I thought about that, but it runs fine for several minutes. [10 the first time and nearly that the 2nd.] It's just that once I turn it off, it won't restart.
My Chilton's manual says something about unplugging the battery resetting the "Keep Memory Alive" and it having to relearn info about your car. I wondered if, once it runs again and relearns, it decides something's not OK and won't start.
Old 07-29-2011, 04:41 PM   #6
Doesn't seem to be the fuel pump, but I wouldn't completly rule it out yet. Your not throwing any codes?
[SIGPIC][/SIGPIC]
Old 07-30-2011, 12:56 AM   #7
kickerofdoom's Avatar
Hmm if I remember right there is a button In the back that can cut off the fuel
Old 09-19-2011, 07:00 AM   #8
I'm terrible at this kind of thing and would have taken it to a garage
Did you manage to figure out what was causing it?
JohnJCs is offline   Reply With Quote
Old 09-20-2011, 05:23 AM   #9
I finally broke down and took off the fuel tank. So nasty and rusted...the fuel filter was way past its prime. Cleaned everything and replaced the filter. All running well now.
Keyless Start poloka 2011-2014 Mustang GT 20 08-03-2011 01:44 PM
Where do I start? dmunoz Classic Mustangs 4 07-22-2011 08:34 PM
4.0 flutters/almost dies upon start up blownranger 2005-2010 V6 Mustang 0 06-28-2011 04:18 PM
good bolt ons to start with? vinnygt 1996-2004 Mustang GT 57 06-24-2011 06:03 PM
02:39 PM
