cutting springs.. - Mustang Evolution
Old 09-15-2007, 06:09 PM   #1
cutting springs..
i was just wondering if anyone has ever cut there springs..i was thinkin about cuttin my spings...
x99xstangxx is offline   Reply With Quote
Old 09-15-2007, 06:58 PM   #2
Re: cutting springs..
Yes...ride quality hasn't changed at all...cut 3/4 coil of the rear springs...lowered my car about 1.5"....
If you don't have the dough for lowering springs, there is nothing wrong with cutting your stockers. It will be perfectly fine.
I would suggest starting with about 1/2-3/4 coil in the rear to start...and about the same up front. Start small and cut small additional amounts until you get the height you are looking for. You can't add coil, so don't cut too much at once.
Word of advice...if you cut them and re-install them and don't like the ride height...drive the car around the block before you decide to cut more. My car settled about 1/2-3/4" after driving.
Old 09-18-2007, 11:17 AM   #3
shamdoodie's Avatar
Send a message via ICQ to shamdoodie Send a message via AIM to shamdoodie Send a message via Yahoo to shamdoodie
+1 on the above. did it four months ago and after they settled, i have had no problems. i'll eventually get actual lowering springs since this was only a test.
drive it like you stole it... just dont wreck it.
shamdoodie is offline   Reply With Quote
Old 09-18-2007, 11:25 AM   #4
I'm glad I went this route too because I am planning on coil overs now...so I won't be out the price of the lowering springs when I do.
Old 09-26-2007, 05:14 PM   #5
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Does any know of a guide/tutorial on cutting my springs process? Is it really that easy to cut the springs or am I confusing the terminology? Any tips? Does this mean that after market springs are completely unnecessary or do aftermarket have a higher performance than cutting them?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 09-26-2007, 05:23 PM   #6
Cutting springs is just a way to save some money and achieve the ride height you are wanting. The major advantage to going with different springs is the advancement in handling you receive.
If you are looking for a way to get better handling and a more aggressive height without breaking the bank look into ford c springs, that's what I have on my car right now and I love them.
Old 09-27-2007, 08:52 AM   #7
Herbstang's Avatar
If done correctly, the cons are minimized. Needless to say the shorter the spring the higher the spring rate has to be. Cutting a coil spring will raise the spring rate. Chances are you could probably cut 1 coil to lower the car. Just guessing here, but that should drop the car about an inch. To go more than, then new springs should be purchased. Although cutting them does increase the spring rate, it will not increase enough for larger drops. The other thing is that a spring is preloaded. If cut too much is will not be and there is a possibilty that the spring could come out of the pocket when the suspension is unloaded.
Cutting the springs is fairly easy. A cutoff wheel can be used. If you look at a spring, you'll see the end coils are bent to make the ends flat. This is done so the spring sits flat in the pockets.
Cutting springs is not anything new. Working with springs under load can be dangerous. Always take precautions, treat them with some respect, and buy the proper tools.
Old 09-27-2007, 09:39 AM   #8
rydog's Avatar
Send a message via MSN to rydog
Make sure you take them out to cut them I have done it multiple times with no problems do not cut more than 1 coil off. One coil will lower it about 1.5" after it has settled
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 09-27-2007, 09:55 AM   #9
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Won't he need caster camber plates and a alignment after he cuts them?
2004 mach 1 stock and staying that way.
1996stang is offline   Reply With Quote
Old 09-27-2007, 11:24 AM   #10
Herbstang's Avatar
I would think so
Old 11-06-2007, 07:34 PM   #11
what is a good set of camber plates without spending too much??
emir45 is offline   Reply With Quote
Old 11-07-2007, 07:03 AM   #12
maximum motorsport cc plates are the best on the market and they run like 189 a set. They are 4 bolt so they are stronger. They come with a lifetime warranty and they offer nearly twice the adjustment that other brands offer. You can wind up with a set that wont give you enough adjustment~ so fyi.
only cut your springs with a cutoff wheel do not use a torch or anything like that, ONLY cut them.
our sponsor atomic performance is offering a bit of a discount if I remember right to our forum members so that will help you on those cc plates as well so check their site out.
cutting stock springs sonicpony03 Pre-2005 V6 Mustang 11 06-24-2009 07:21 AM
cutting springs? BlackSix Pre-2005 V6 Mustang 17 11-24-2008 09:50 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
Cutting Your Springs megax29 Pre-2005 V6 Mustang 45 10-13-2004 04:36 PM
cutting C springs ???? Zim Pre-2005 V6 Mustang 8 06-24-2004 12:59 PM
07:38 PM
