No love for older V6's? - Mustang Evolution
Old 08-05-2011, 02:55 PM   #1
SBrady9's Avatar
I have a 96 V6 but the two forums I'm seeing on my iPhone app for the V6 are for newer models. Anyone have a 94-99 V6 or have had one. Mines been a headache lately with a lot of things going so I was wondering if others had these problems and if they know what will be going next?
Alternator went
Head gaskets blew
Replaced spark plugs and wires
Radiator hose sprung a leak
Transmission sometimes won't shift out of 1st when in drive (automatic)
Radiator fan/motor seized
All of this since December
SBrady9 is offline   Reply With Quote
Old 08-05-2011, 03:49 PM   #2
Blackheart4355's Avatar
Well...if the car has had little to no maintenance then these are pretty common things to go after 15 years. If you hadn't replaced the water pump and timing chain then you might want to replace that as well.
---------- Post added at 02:49 PM ---------- Previous post was at 02:47 PM ----------
I owned a 98 from 99 to 01. It was a great car..had lots of fun with it.
Blackheart4355 is offline   Reply With Quote
Old 08-05-2011, 04:37 PM   #3
SBrady9's Avatar
Thanks
---------- Post added at 06:37 PM ---------- Previous post was at 06:27 PM ----------
Forgot to mention that the car only has 98k on it.
Old 08-05-2011, 04:43 PM   #4
Well..
Some parts are milage related and some just over time need to be replaced. At 98k you definitely will need to change your water pump and timing chain. The others are pretty much expected considering the age of the car.
Old 08-05-2011, 04:44 PM   #5
Las0mbra's Avatar
Originally Posted by Blackheart4355
Well..
+1, like the hoses are completely understandable, the motor will go out too, along with the alternator failing after all those years.
Old 08-05-2011, 05:14 PM   #6
SBrady9's Avatar
Have either of you changed out the water pump yourselves? Doable?
Old 08-05-2011, 05:15 PM   #7
Las0mbra's Avatar
I've never done it... I'd post a thread about it in the general v6 section and I'm sure you'll get some responses.
Old 08-05-2011, 10:05 PM   #8
I personally have not..but mine was replaced by my engine builder when I had the heads, cam and roller rockers done.
Old 08-06-2011, 07:00 AM   #9
stampde's Avatar
Re: No love for older V6's?
and the 3.8's are notorious for bad head gaskets ,, you have to flush the coolant system in those engines every 25 to 30 thousand miles
2011 GT Auto
Old 08-06-2011, 08:32 AM   #10
SBrady9's Avatar
Yeah I read about that when I first got the car because it was going through coolant fast. I think there was already something wrong with it then. I flushed the coolant and it blew a couple months later.
Old 08-06-2011, 09:10 AM   #11
I believe Ford corrected the issue with redesigned head gaskets...my 98 I believe had them replaced under recall....
Love the Beast junoS197Bl08 General Car Discussion 0 07-12-2011 09:29 AM
Check s mcqueen out - gt390 love it Mustangjm Classic Mustangs 13 06-26-2011 11:34 AM
09:01 AM
