next step - Mustang Evolution
Old 08-05-2011, 04:39 PM   #1
kickerofdoom's Avatar
next step
I got basic bolts on thinking of adding a Windstar intake or adding nitrious how much for a set up of nitrious
Old 08-05-2011, 05:43 PM   #2
Go with the winstar I love mine and all depends on how much you want to spend , new or used... But a good set up needs a tune, window switch and bottle warmer. Zed has a nice window switch witch works with air to fuel ratio to eliminate pre detonation. And your better off with a wet kit.
Svt4me is offline   Reply With Quote
Old 08-05-2011, 06:03 PM   #3
Las0mbra's Avatar
For nitrous, pm knight f Mohawk.. He's a distributor and could get you a good deal at Cold Fusion Nitrous. Like $460ish?
And yeah, the windstar kit is nice, I'd do it if I had the cash
Old 08-05-2011, 06:26 PM   #4
I want the Windstar but I'm thinking of doing a junkyard swap
Old 08-05-2011, 10:10 PM   #5
Blackheart4355's Avatar
Ok,
Go with the VAP Auto kit. It gives you everything you need plus you get your throttle body altered and the spacer you require for it all to clear the hood.
Blackheart4355 is offline   Reply With Quote
Old 08-05-2011, 10:14 PM   #6
Las0mbra's Avatar
Originally Posted by Blackheart4355
Ok,
+1... or atleast get the modified tb and spacer... You'll have buy a new hood if you don't.
Old 08-05-2011, 10:35 PM   #7
There are other things that Stephan does to get the intake prep'd for use on a Mustang. It is just easier to go with his kit.
Old 08-05-2011, 10:40 PM   #8
Re: next step
You can get a nitrous setup for cheap...all the extras aren't necessary. I would, however, recommend a tune with any nitrous.
Old 08-05-2011, 11:07 PM   #9
Well, In my opinion nitrous should be a last resort once all your other engine mods are done. Once you get the engine where you want it, then add nitrous IF you still need or want it. But that's just me.
Old 08-05-2011, 11:34 PM   #10
Windstar van can you take other parts from.the car and what else can u add to the engine from other 3.8
Old 08-05-2011, 11:43 PM   #11
That's it for engine stuff..but I think the Aerostar reared is swappable.
Old 08-06-2011, 02:21 PM   #12
Project Pony's Avatar
Re: next step
I second saving the boost juice for last, and definitely a custom tune to make everything play nice.
[SIGPIC][/SIGPIC]
Next step GTtopgear 1996-2004 Mustang GT 0 07-30-2011 08:47 PM
12:48 PM
