Rear end - Mustang Evolution
Old 08-14-2011, 09:07 PM   #1
BigSteve305's Avatar
Rear end
Think my rear end is going changed it a year ago. It was making a humming sound. Now it's doing again but not as loud it's a slight humming sound. You think maybe it's leaking gear fluid? Should I be concerned?
BigSteve305 is offline   Reply With Quote
Old 08-14-2011, 09:12 PM   #2
Hunter's Avatar
You could be leaking fluid and that would cause the humming because of low fluid. Cauisng friction. Best beat would be to drain the fluid. Check the gears. If everything is ok then put it back together. When putting the cover back on with the new gasket. Use ultra copper. That stuff is amazing and seals eveything up really well. Good luck
_____________
Landis
Hunter is offline   Reply With Quote
Old 08-14-2011, 09:19 PM   #3
It has a weird smell too. I smelled it once. Almost smells like burnt rubber. I shouldn't be driving my car then if I'm leaking the fluid cuz if it leaks all out it will lock up right?
Old 08-14-2011, 10:27 PM   #4
I actually just noticed it only hums in 3rd gear. Does that Mean my gear is bad?
Old 08-15-2011, 07:39 AM   #5
Re: Rear end
could be fluid, or just the gears are whining, does it go away when you either get on the gas or let off, or between MPH ranges its worse or gone etc?
Old 08-15-2011, 09:25 AM   #6
It's only does it in 3rd gear when I hit the gas it goes away. When I let go of the gas it will still do it for like 5-10 secs then go away
What size gear for rear end? BlackBeauty01 1996-2004 Mustang GT 21 09-02-2011 08:00 PM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 03:15 PM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 06:59 PM
Any idea of what rear end gears i may have in my 92 GT? macmarine39 1979-1995 Mustang GT 4 07-16-2011 08:25 PM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
03:56 AM
