91 Block the same as 94+? - Mustang Evolution
Old 11-02-2003, 10:10 AM   #1
I can get a 91 3.8 block for free and wondering if it would cause any problems with a 94-98 engine if I were to get it bored etc...
Old 11-02-2003, 11:36 AM   #2
I am 99.999999999999999999999999999% sure it is the same.
But a free engine is a free engine. Take it!
Extreme Effects.com is offline   Reply With Quote
Old 11-02-2003, 12:41 PM   #3
alright I am waiting on Brandon to get me some pics so I can see what condition its in. If its in good condition then its mine.
Old 11-02-2003, 01:16 PM   #4
Danger Dude's Avatar
It is the same. there was a change in 88 and from 89 to 95 nothing was done internally again till 96
For you reading enjoyment http://www.babcox.com/editorial/ar/ar90134.htm
Old 11-02-2003, 01:23 PM   #5
well crap the next car I get is going to be a 96-97..... what was the change in 96 and will it affect the '91 block
Old 11-02-2003, 01:26 PM   #6
basically the block was reinforced in some areas and the heads were changed. There was a casting number change between 96 and 97 but nothing appeared to be changed
Old 11-06-2003, 11:30 AM   #7
RGR
Send a message via AIM to RGR
I believe there is complete compatibility from
89-98 but you must use 96-98 heads with a
96-98 lower intake or mod the intakes to fit the
heads, but it is an easy mod. You also have to
use the same year gaskets as the intakes are.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 11-06-2003, 07:55 PM   #8
Ok If I sent the block to you what would you suggest the best thing to do with it be
Old 11-07-2003, 05:04 AM   #9
RGR
Big Bore and forged pistons, stock (forged) rods
High RPM NA use, baby!
SC crank for sale probably, I could use the $$$
and you could use the forged steel crank strength!
I have done lots of measuring and research, I
have found that the bigger bores on a V6 should be very
safe with the proper machining and such, my machinist
has done V6 blocks .060" over and it was great, more is possible.
BV heads and a big cam to top it all off! 1.8 RR's
on top of that and the level 2 springs wil complete the pkg.
Old 11-07-2003, 08:03 AM   #10
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I thought older blocks, (may its just supercoupes)
Have something different with their coolant lines. Like they had a different coolant line comming out of the block.
Is that true?
Rellik is offline   Reply With Quote
Old 11-07-2003, 08:13 AM   #11
In the older blocks they had a few extra coolant holes running thru the block and head but a couple were 2 close to the cylinder on the heaad side causing the head problem in 96 they changed the design in 96-97 and futher in 98. Actuall the 98 block is identical to the 99 block minus the new top end stuff
Where to get a 4.2 block Zebs5408 Pre-2005 V6 Mustang 10 02-27-2010 01:46 PM
5.0 on a 4.6 block. DaDant! 1996-2004 Mustang GT 2 02-06-2009 08:35 PM
302 Block Help ejl22boo 1979-1995 Mustang GT 2 02-01-2009 07:50 AM
4.6L Block hawks05 Mustang Parts for Sale and Wanted 1 03-30-2005 01:16 AM
4.2 Block n8r Pre-2005 V6 Mustang 5 06-12-2004 10:10 AM
09:57 PM
