mechanics please help! - Mustang Evolution
Old 08-22-2011, 05:38 PM   #1
austinknoll's Avatar
My car is misfiring like crazy! I checked the codes it was a misfire in cylinder 1. Pulled the plug, was pretty dirty cleaned it off and put it back in and it misfires even worse! I bought e new plug today and put it in and same thing. I have replaced all the plugs and wires, cleaned MAF sensor. Would it be a coil pack?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 08-22-2011, 05:57 PM   #2
If youve already checked everything else then yes I would think it's the coil pack, get a test light and test the individual wires on the connector for the pack. Hate to see ya waste money.
Cody156 is offline   Reply With Quote
Old 08-22-2011, 07:56 PM   #3
Bought a coil pack, it helped slot but still lost power and misfirng. There was a dead hole on the old coil pack
65 Mustang coupe
Old 08-22-2011, 08:28 PM   #4
Hmm is that wire still dead or was it just the pack
Old 08-22-2011, 08:38 PM   #5
Nag we put he old wire on it and we tested it before we put it on and it worked :/
65 Mustang coupe
Old 08-22-2011, 09:29 PM   #6
Check your fuel injectors. Take the injector from #1 and switch with another. If your still getting PO301 then I have no idea. But it should switch codes to PO302,303,304,305, or 306. Let me know how that turns out.
Old 08-22-2011, 10:05 PM   #7
Aren't fuel injectors hard to get to?
65 Mustang coupe
Old 08-22-2011, 10:23 PM   #8
Yes, pretty much it's removing your upper intake. Chances are that's your problem, Im willing to bet one of your injectors is clogged
---------- Post added at 11:23 PM ---------- Previous post was at 11:17 PM ----------
Yes, you'll have to remove the upper intake manifold. I think it's a clogged injector, get a second opinion before you start dismantling
Old 08-23-2011, 10:20 PM   #9
So get this, I pulled everything off except the fuel injectors. I wa waiting for my dad to get home to help me put a little and I forgot to release the pressure in the fuel lines. So I pulled the plug on the litttle sensor and put it back together. Put the negative terminal back on and strapped everyting together. I go for a drive to my girlfriends house and it ran like the day I bought it. Idk why weird.
65 Mustang coupe
Old 08-23-2011, 10:58 PM   #10
Uhhhhhh????? Hahaha. Who knows man, glad it worked out tho
Old 08-24-2011, 10:46 PM   #11
Haha I know I was trippin for a minute there
65 Mustang coupe
» Members Mustangs
Bella
dmunoz
Cool One
GTGirl
Add your Mustang
09:14 AM
