think my fan went out? - Mustang Evolution
Old 09-01-2011, 12:42 PM   #1
not sure but i think my fan is completely dead. i noticed the ac hasnt ben blowing cold at all the car is not overheating though. i ran it for 20 to 30 mins. just now and no fan. should i order a new fan or take it in to the shop.
jblitz99 is offline   Reply With Quote
Old 09-01-2011, 02:18 PM   #2
93slowstang's Avatar
It may be the relay.
Old 09-01-2011, 02:43 PM   #3
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
make sure its pluged up first and use a volt meter and see if its getting power
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-01-2011, 03:06 PM   #4
ForsakenProto's Avatar
If it's blowing but not cold it may just need to have it's ac recharged, some auto stores sell a kit to do it yourself, and most shops can do it too.
ForsakenProto is offline   Reply With Quote
Old 09-02-2011, 03:24 AM   #5
derekb_'s Avatar
+1 sounds like you just need a recharge
derekb_ is offline   Reply With Quote
Old 09-02-2011, 06:28 AM   #6
illestdomer2005's Avatar
If you're feeling any air, it's not your fan. If your car is newer and never been recharged, I would try that. Hopefully, it's not your compressor because replacing those things is expensive!
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 09-02-2011, 06:40 AM   #7
00STANG00's Avatar
very buy a mustang book it tells you how to replace if need be and what to check to avoid breakage.
SUCK MY DUST
Old 09-02-2011, 07:26 AM   #8
Project Pony's Avatar
Re: think my fan went out?
Start the car and let it idle for a bit, after several minutes the fan should kick on. If it does not kick on after a while I agree with checking the connections and make sure it is getting power. If it comes on then try watching the compressor with the ac on. Look to see if the clutch enganges and it to cycle on. If all seems well the you may just need a recharge. There are still a few possiblities i.e bad compressor, leak in the lines etc. A shop can check all of this for you to better determine what your issues is. I would think the best case senario would be that you need to top of the r12 which a can should run you about 20-25 bucks.
[SIGPIC][/SIGPIC]
Old 09-02-2011, 01:27 PM   #9
thanks everyone, turns out it was just a relay.
Old 09-02-2011, 01:38 PM   #10
Excelllent! Much cheaper fix
Cooling fan help!! zrider07 1996-2004 Mustang GT 9 08-16-2011 09:47 AM
Another Issue (overheating) bradh2414 Pre-2005 V6 Mustang 18 07-27-2011 03:19 PM
radiator fan shady Pre-2005 V6 Mustang 6 07-27-2011 12:42 PM
Cooling fan??? zrider07 1996-2004 Mustang GT 4 07-25-2011 09:38 PM
Cooling fan and AC problem, please help 95GTS 1979-1995 Mustang GT 4 07-08-2011 08:24 PM
02:34 PM
