4.2L Stroker - Mustang Evolution
Old 09-06-2011, 08:08 PM   #1
Blackheart4355's Avatar
OK,
I'm thinking about doing a 4.2L stroker. So I know I need a crank, piston and rods as well as the 310 LPM fuel pulp. But I have questions. Does it have to come from an F150 or can it be from a Freestar? Do I need to go to bigger injectors and if so how big and from what? Oh and I don't want to hear any why are you doing this, it costs too much for too little gains crap. I'm just looking for valuable input and expertise here.
Thanks
Oh and I know there are kits out there, but I will likely buy the required bits a piece at a time as I can afford it over the winter.
Blackheart4355 is offline   Reply With Quote
Old 09-07-2011, 05:38 AM   #2
bmabbott's Avatar
Re: 4.2L Stroker
Tom Morana Racing Engines
here's a fully compatible kit, but it's really pricey! I will be doing this conversion next summer, si good luck, and I'll be hounding you with questions when you're done! I'm going 4.2 with an m90 blower...
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 09-07-2011, 02:42 PM   #3
Mmmm....how you going to mount a blower for a single port application onto a spot port engine?
Old 09-07-2011, 03:09 PM   #4
Las0mbra's Avatar
I'd do the 4.2, and then an m112! It actually fits on the 99-04 v6s
Old 09-07-2011, 03:31 PM   #5
bmabbott's Avatar
Re: 4.2L Stroker
I have a single port v6, the m90 blower was on the 89-94 supercoupe 3.8l SINGLE PORT engine... it's nearly directly compatible... I just have to do a little work on my lower intake.
---------- Post added at 04:31 PM ---------- Previous post was at 04:31 PM ----------
I have a 98... m90 for me
Old 09-07-2011, 03:32 PM   #6
Las0mbra's Avatar
Oh yeah, ha, sorry... I should've know from your picture. But why not do a splitport swap while your at it? You'll gain way more power with the swap, 4.2 stroker kit, and an m112.
Old 09-07-2011, 03:36 PM   #7
Or do the split port swap to maximize the 4.2 stroker. But you are kinda hijacking my thread......
Old 09-07-2011, 03:39 PM   #8
bmabbott's Avatar
Re: 4.2L Stroker
but, back to the 4.2l topic... I believe Ford had a 4.2L v6 engine in their 97-99 f150 that you can take the crank, rods and pistons out of....
---------- Post added at 04:39 PM ---------- Previous post was at 04:38 PM ----------
ok... sorry... no more advice from me
Old 09-07-2011, 03:42 PM   #9
Yes, you are correct...the Freestar was 4.2l as well...but I don't know if the parts are interchangeable. I also heard the 310 LPH fuel pump can be sourced from an SVT Focus...I also heard you need bigger injectors...but from where and how big do they need to be?
---------- Post added at 02:42 PM ---------- Previous post was at 02:41 PM ----------
No worries advice is welcome...and I kinda did start down the road to the questions put to you...I was just trying to get the thread back on track. Sorry....
Old 09-07-2011, 08:39 PM   #10
No help out there?
Old 09-07-2011, 09:44 PM   #11
Las0mbra's Avatar
I'd do a google search. I think I remember seeing a complete 4.2 swap writeup on another forum
Old 09-07-2011, 10:13 PM   #12
Really? Because I did a search in hopes of finding something like that and came up empty....
Old 09-08-2011, 05:41 AM   #13
bmabbott's Avatar
Re: 4.2L Stroker
How to: 4.2L V6 Mustang Engine Swap
Old 09-08-2011, 02:34 PM   #14
Thanks for the link. It doesn't touch on fuel system though.Are bigger injectors required?
Old 09-09-2011, 11:45 AM   #15
Yes...no?
Old 09-12-2011, 04:16 PM   #16
DSGstang513's Avatar
Use the ones from the 4.2L I believe
DSGstang513 is offline   Reply With Quote
Old 09-12-2011, 07:36 PM   #17
What size are they?
Old 09-13-2011, 02:34 PM   #18
I'm not too sure you could just upgrade to 36lb and call it a day not need to worry about upgrading again
Old 09-13-2011, 04:38 PM   #19
Ok...and what year/model came with 36lbs injectors...Mustang GT's?
Old 09-13-2011, 04:47 PM   #20
No gts has 24 pound injectors you would have to go after market and also get the ev6 connectors or go aftermarket on 42s
Old 09-13-2011, 08:46 PM   #21
What do our cars have?
Old 09-13-2011, 08:48 PM   #22
Ghostedmind's Avatar
I want to say I remember reading somewhere that they have 19# injectors stock
LCMC Member
Old 09-13-2011, 08:51 PM   #23
That might be right I'm not sure I believe our v6 cars have bigger injectors
Old 09-17-2011, 09:17 PM   #24
bmabbott's Avatar
Re: 4.2L Stroker
I think they are 19# on 99-04 v6. I know my 98 has 14#. When I go with the 4.2 Stroker on mine, I am planning on using 24# injectors, because my 14# won't work with the stroker and forced induction combo... It's always best to go a little bigger than what you think you may need, because you can always make larger injectors act small... but the stock 19# ones may work for your split-port with the stroker...
Old 10-12-2014, 12:31 AM   #25
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Smile
The early tBird SC came with 30lb injectors and the 94-95 came with 36lb injectors. So could use those...
Jmustang78 is offline   Reply With Quote
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
How much does a 371 stroker kit cost? 94GTx306 1979-1995 Mustang GT 2 07-30-2011 09:25 PM
4.2L engine from a 98 3.8L bmabbott Pre-2005 V6 Mustang 11 07-01-2011 09:09 PM
02:41 PM
