oil question - Mustang Evolution
Old 09-07-2011, 03:52 AM   #1
CancerBoi69's Avatar
oil question
Wen should you bump up the weight of your motor oil rite now im at 140000 miles on my 05 v6 n using 5w-20 royal purple with k&n oil filter. What is my next weight option
CancerBoi69 is offline   Reply With Quote
Old 09-07-2011, 04:18 AM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
10 w 30 will be the best
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-07-2011, 04:39 AM   #3
Jamesgt08's Avatar
Never use 5w-20.
20 is to low. It protects ur car like water wen it gets hot it thins out to much.
Jamesgt08 is offline   Reply With Quote
Old 09-07-2011, 04:59 AM   #4
Ya I noticed that wen I change my oil its really tine. 10-30 is ok that's a big jump isn't it?
Old 09-07-2011, 05:01 AM   #5
Jamesgt08's Avatar
10-30 is what i use and i have 155xxx miles.
Old 09-07-2011, 05:21 AM   #6
When your oil is tine will it mess up your preformance n ect
Old 09-07-2011, 05:44 AM   #7
00STANG00's Avatar
hell ya
SUCK MY DUST
Old 09-07-2011, 05:45 AM   #8
Lol
Old 09-07-2011, 05:50 AM   #9
00STANG00's Avatar
thin is never good with oil
SUCK MY DUST
Old 09-07-2011, 06:48 AM   #10
Re: oil question
Spec for my 3.8L is 5W30. I have about 220,000 miles on the engine now and i just use 10W30 in summer and 5W30 in the winter. Mobil1 Extended Service is what I have run for the last 100,00 miles+. That and a Mobil1 oil filter. Sometimes a K&N oil filter, and sometimes a Motorcraft oil filter. Depends on where I am when I pick up the oil.
Old 09-07-2011, 06:53 AM   #11
00STANG00's Avatar
i use 10 w 30 all year round i add that lucas oil treatment every oil change. im due for a fuel filter and a oil change now its black as coal
SUCK MY DUST
Old 09-07-2011, 07:52 AM   #12
Re: oil question
Just some FYI for anyone interested:
Amsoil Signature Series oils are guaranteed 25,000 miles or one year which ever comes first,
Royal Purple has a redesigned oil filter far superior than anything on the market now and can be purchased from American Muscle cheap and free shipping.
Just some info, hope it's useful to someone out there!
Old 09-07-2011, 08:01 AM   #13
Is it good for my v6 mustang?
Blackedout is offline   Reply With Quote
Old 09-07-2011, 08:16 AM   #14
93slowstang's Avatar
10w30 won't hurt your car at all. Its not much thicker than 5w30.
Old 09-07-2011, 08:32 AM   #15
Re: oil question
You can prop up your hood and the recommended weight is there. If you feel your seals are wearing, upping it by 5W in the summer won't hurt. If you can keep it running with 5W without noisy lifters, do it. A good Seafoam treatment to the upper intake manifold does wonders.
Old 09-07-2011, 08:32 AM   #16
00STANG00's Avatar
do you know what it means 10 w 30?
SUCK MY DUST
Old 09-07-2011, 08:32 AM   #17
Rocco4.6's Avatar
I have an 02 gt and never ran synthetic oil in it before is it ok to change or better to stick with what's been used for soo long?
Rocco4.6 is offline   Reply With Quote
Old 09-07-2011, 08:35 AM   #18
00STANG00's Avatar
also true even though you change you oil some of the old is still in there
SUCK MY DUST
Old 09-07-2011, 09:36 AM   #19
Re: oil question
You can change over to synthetic at anytime as long as you do not have any oil leaks presently.
Old 09-07-2011, 12:24 PM   #20
Rocco4.6's Avatar
What happens if there are any leaks?
Old 09-07-2011, 12:26 PM   #21
00STANG00's Avatar
a very hot car and engine blowment. a oil leak is never good
SUCK MY DUST
Old 09-07-2011, 03:54 PM   #22
Rocco4.6's Avatar
So I should probably stick to regular
Old 09-07-2011, 04:03 PM   #23
00STANG00's Avatar
thickish and not that cheap stuff
SUCK MY DUST
Old 09-07-2011, 06:24 PM   #24
Re: oil question
If there is already a leak present, then it will leak more because of how slippery the synthetic is. It will find its way out of the engine quicker. Synthetic oil is cheaper to use than carbon based because of the longer change intervals. It gives Superior protection for the engine and is cheaper to use in the long run.
Six quarts of the Amsoil will cost $35.00 and last 12 months. Six quarts of conventional oil will cost $12.00 X4(change every 3 months)=$48.00 plus the time, effort, and dirty oil that has to be disposed of properly.
Understand?
Old 09-07-2011, 07:52 PM   #25
Rocco4.6's Avatar
I don't have any leaks but just wondering if it was a big deal or not
Old 09-07-2011, 07:54 PM   #26
00STANG00's Avatar
it can
SUCK MY DUST
Old 09-07-2011, 10:33 PM   #27
Re: oil question
If Ford recommends 5W-20 for your engine, then you are already using some of the best possible oil+filter to keep your car running for a long, long time. Clearance tolerances can not tolerate more than 5W weight oil without causing damage to the engine.
Contact someone from Ford and ask. Preferably not a local mechanic at the dealership. Google and research someone with Ford that works in the engineering/development department. they will tell you the same and explain better than I can.
-Royal Purple is great stuff
-K&N oil filters are of the highest quality.
You are doing just fine. Consult your owners manual.
Old 09-08-2011, 03:21 AM   #28
Thanx alot just wanted to make sure cuz a guy I work with said I should up my weight cuz of the amount of miles I have on my Stang and plus with it being so hot in texas
Old 09-09-2011, 07:50 AM   #29
Ghostedmind's Avatar
Re: oil question
Motor Oil Viscosity Grades Explained in Layman's Terms
I thought this explained what the difference is in the viscosities real well....and what i got off of it is it doesnt matter if its 5W or 10W it wont hurt your engine....the main one is the last number... you want it a little higher. the 5 or 10W just tells you how easily it will start moving around parts when the engine is cold or in a colder enviroment
Old 09-09-2011, 09:32 AM   #30
illestdomer2005's Avatar
Re: oil question
What I understood is that newer engines that get better compression ratios can tolerate and maybe prefer the lower weight oil. Older engines actually need the heavier weight.
For my wife's car (1999 Ford Contour 2.5L V6), she has ALWAYS had 10w30 put in. The last oil change saw some dufus put 5w20 in, and we witnessed major engine trauma two days later. Coincidence?
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 09-09-2011, 09:36 AM   #31
Re: oil question
I run 5w-30 instead of 5w-20, after reading MANY articles and much research 5w-30 protects better and works great~ the 5w-20 was only used for emissions and is a thinner oil and thus does not protect quite as good. Its still within tolerance on my car to run 5w-30.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
Random quick oil question? SHADOWX777 Pre-2005 V6 Mustang 2 08-21-2011 06:24 AM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-14-2011 11:43 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 01:17 PM
12:09 PM
