plz read - Mustang Evolution
Old 09-08-2011, 04:17 AM   #1
CancerBoi69's Avatar
plz read
Does size matter when it comes to air filters attached to cold air intake tube and also wats the best way to sea form your car and wen should it be done
CancerBoi69 is offline   Reply With Quote
Old 09-08-2011, 04:46 AM   #2
Re: plz read
My old lady always says size doesn't matter but I think she's just trying to make me feel good.
Now, with CAI filters, size usually comes into play because of limited space where they are located. I use a K&N because that's my choice. My wheel well would only allow a filter six inches i believe, so that was my only option.
Seafoaming: You purchase two cans. One full can goes into the gas tank. The second can gets introduced into the upper intake manifold while the engine is running by sucking it up through a vacuum line. I usually put a drinking straw inside the can to make it easier. You can then place the end of the straw sticking out up to a vacuum line and let it suck it up. A simple way to do it is to pull the pcv valve out and pull it up (The Seafoam) and in through there. I use the one atop the upper intake plenum next to the throttle body. I Seafoam my upper intake at least every three thousand miles.
The difference in performance and gas mileage is just incredible. Any questions, just ask!
Old 09-08-2011, 06:48 AM   #3
Im lost on which line can you proved a pic lol sry
Old 09-08-2011, 07:42 AM   #4
Re: plz read
Yes. I will do that right now. Give me a few to take the pictures and then give a try to Photoshop or whatever for the first time . I'm on it. Hang on a few- Robb
Old 09-08-2011, 07:56 AM   #5
Ok
Old 09-08-2011, 08:41 AM   #6
Re: plz read
OK, Here We Go!
This is the part of the engine where vacuum lines are located-
This is the upper intake
This is location of PCV
This the pcv valve pulled out and what is going to suck the Seafoam into the upper intake through the straw
When I soak the upper plenum, I turn the engine off while still warm, I disconnect this hose and pour couple of onzes inside to soak for 20 min and then start er up and go for a ride and gun it. It will smoke.
THAT IS IT!
Old 09-08-2011, 06:50 PM   #7
Ghostedmind's Avatar
Re: plz read
How To Seafoam Your Car & Clean Carbon Buildup | Tech Aids & Articles
That is what i used, except i didnt do the oil part the last time i did it. but i am going to be doing it soon. I can definately say it helped a LOT
Old 09-08-2011, 08:36 PM   #8
Is the pcv vaule located in the same spot on the 05 v6
Old 09-08-2011, 10:55 PM   #9
Re: plz read
It will be located on one of the two valve covers somewhere for sure.
---------- Post added at 11:55 PM ---------- Previous post was at 11:51 PM ----------
I personally would never put it in my oil unless somehow the engine severly overheated and baked the oil inside. I just keep changing my oil and filter when it's due. Using Mobil1 extended service 5W-30 and a Mobil1 OR K&N oil filter.
Old 09-08-2011, 11:01 PM   #10
Hey Wat will be best the break booster or pcv
Old 09-09-2011, 03:56 AM   #11
Re: plz read
Break Booster.
Add it in small amounts while a helper mans the throttle body giving it gas when it feels like it wants to stall.
Old 09-09-2011, 08:25 AM   #12
Re: plz read
I used the brake booster and hooked up a funnel to it using another piece of spare rubber tube that way i could watch how much i was putting in easier
Old 09-09-2011, 10:35 AM   #13
illestdomer2005's Avatar
Re: plz read
At what point should you consider "Seafoaming"? Obviously, my 2011 doesn't need it yet, but is it an age thing? Miles? Some other indicator?
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 09-09-2011, 10:38 AM   #14
Re: plz read
you can seafoam when ever you want. I would do it once or twice a year... they say its not good for supercharged cars thus I have never done it... but its a great way to PREVENT buildup from taking place and getting bad.
You could make it a yearly thing, like a spring time regular todo list type thing.
Old 09-09-2011, 11:31 AM   #15
Re: plz read
Interesting. So, since it is a new car, can I just simply add it to my fuel tank, or do I need to do the whole PCV treatment as Robb described?
Old 09-09-2011, 09:41 PM   #16
Re: plz read
It would be just in the gas tank for you.
The 3.8L engines pull in an abundant amount of oil vapor through the pcv system. A quality catch can is a great recommendation for any Mustang. Several people make them. They make them specific to your car too. Its plug and play. Provides the catch can, hoses and tubing including a new pcv valve. Sold as kits for your particular engine.
Its the V6's that are plagued with sludge from oil vapor built up.
Any of you guys with SCT Tuners might want to read... illestdomer2005 2011-2014 V6 Mustang 15 09-12-2011 11:03 PM
Mustang5.0 supercharged tuning qustion help plz Fox5.0 1979-1995 Mustang GT 8 08-28-2011 03:36 PM
Help!!!! Plz 04machazblue 1996-2004 Mustang GT 2 08-27-2011 01:01 PM
1st classic need help plz Nate98stang Classic Mustangs 18 08-06-2011 11:16 PM
Want to Mod and have Warranty READ THIS! SpectorV General Mustang Discussion 4 07-21-2011 03:33 PM
08:22 PM
