for those of you who have installed the vap windstar kit - Mustang Evolution
Old 09-13-2011, 12:33 PM   #1
getting ready to install mine in a couple days, the instructions are a bit intimidating. any tips or advice that would make the install easier are welcome. also do i really need to remove the inulating pad under the hood? the instructions say to knock off the bolts for the hood scoop which ive done but it also recomends removing that pad?
jblitz99 is offline   Reply With Quote
Old 09-14-2011, 03:11 AM   #2
Just_John's Avatar
Region: South Dakota
Re: for those of you who have installed the vap windstar kit
I just installed mine a few weeks ago. I didn't remove the hood insulation, but I noticed tonight that I can see where the throttle is digging into it a little. It doesn't effect throttle movement so I'm not gonna mess with it. I also noticed a flat spot where the CAI elbow off the throttle body... again, nothing to be concerned with
Did you get the pictures showing the vacuum line connections? If not, ask Steven for a "road map".
I noticed that the nuts and bolts that were included weren't exactly what I needed. I went to Mac's (hardware store chain) and bought a box of assorted black capscrews and black locknuts with nylon inserts to assemble everything.
The didn't like the way the CAI supplied with the Windstar kit went together. I ended up taking pieces from my CAI that I had bought from AM and made it work to my liking.
After a 12 hour shift my brain isn't working well, if I think of anything else I'll post again...
Just_John is offline   Reply With Quote
Old 09-14-2011, 12:38 PM   #3
thanks for the reply. this was included with the instructions. is this the "roadmap"? i sent him a email to see if he had something more indepth.
well it wont upload but it was just a vague small picture of the lines exiting the intake.
Old 09-14-2011, 07:53 PM   #4
Ghostedmind's Avatar
Have you looked at the instructions on the website? The ones I saw had pictures and seemed quite in-depth.....printed out they seem like they would be quite a few pages....let ne know if you can't find them and ill post a link (im on my phone right now or I'd do it now)
LCMC Member
Old 09-14-2011, 11:15 PM   #5
Blackheart4355's Avatar
I used the ones Stephan sent with the kit and had no problems. I had a friend help with the wiring and it seemed to make it go a bit faster. Other than that it went together pretty well. I didn't remove the insulation either. Looks and runs great!
Blackheart4355 is offline   Reply With Quote
Old 09-15-2011, 07:39 PM   #6
so heres the problem i cant get the overflow section bent out of the way enough for the intake to seat properly, also even if it does seat the section will be in the way of the throttle body?
ID:	31832   Click image for larger version
Old 09-15-2011, 07:45 PM   #7
I thought you were supposed to cut off about a quarter inch or so of that?.....or have you already done that?
LCMC Member
Old 09-15-2011, 08:09 PM   #8
yah thats with the top 1/2 inch taken off.
Old 09-15-2011, 08:14 PM   #9
Oh wow
Ok....looking at the third pic u posted...I know the pics in the instructions I looked at were showing to bend it away from the intake(towards the front if the car) .but did you try bending it to the right? (Towards the driver side ) Or?
LCMC Member
Old 09-15-2011, 08:36 PM   #10
i havent but that would be straight toward the radiator hose.
Old 09-15-2011, 08:41 PM   #11
Hmm....couldn't tell how close it was......how much farther would it need to go before it'd clear the TB and intake?
LCMC Member
Old 09-16-2011, 05:23 AM   #12
Is that the only hard part the radiator hose
Blackedout is offline   Reply With Quote
Old 09-16-2011, 07:56 AM   #13
finally got it moved to where it needed to be. had to go way back and then way right. just have to route the vacuum hoses and wiring today.
Old 09-16-2011, 11:31 AM   #14
Cool....glad you were able to get it fixed
LCMC Member
Old 09-17-2011, 11:09 AM   #15
after two days and several beer breaks, ive got it all back together. seems to run fine. ive got alot of slack in my throttle cable now, which im bout to do something about, and im not happy with the way the filter system is, id like to try to use my k&n cai so i might mess with that some more. all in all i guess it wasnt to bad.
Old 09-22-2011, 12:03 PM   #16
It was the only part that gave me trouble. Everything else is bolts and hoses.
Stubzmekenzie is offline   Reply With Quote
FS Windstar kit SerbStang Mustang Parts for Sale and Wanted 19 10-22-2011 04:34 PM
02:22 PM
