Heavy vibration in rear end - Mustang Evolution
Old 09-14-2011, 05:56 AM   #1
When I have my car in park I feel a heavy vibration in the rear end... It's a very distinct vibration.
Blackedout is offline   Reply With Quote
Old 09-14-2011, 12:41 PM   #2
DSGstang513's Avatar
Auto or 5 speed
DSGstang513 is offline   Reply With Quote
Old 09-14-2011, 12:53 PM   #3
Automatic
Old 09-14-2011, 12:59 PM   #4
Could be a number of things the gears the tc or they tranny itself
Old 09-14-2011, 01:00 PM   #5
Brand new transmission.
Old 09-14-2011, 01:07 PM   #6
Hmm drive shaft maybe does it only do it in park?
Old 09-14-2011, 01:35 PM   #7
Yeah only in park
Old 09-14-2011, 02:05 PM   #8
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
i had that problem not only in park but at a stop. took month for me to figure out it was harmomics. but it can get worse and mess something internally. sooner the cheaper.
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-14-2011, 02:13 PM   #9
What's that??? And no check engine light warning???
---------- Post added at 03:13 PM ---------- Previous post was at 03:11 PM ----------
What do I have to change?
Old 09-14-2011, 02:53 PM   #10
00STANG00's Avatar
does the whole car shake or just the back i probally missinterped what you was sayin
---------- Post added at 03:51 PM ---------- Previous post was at 03:46 PM ----------
its a fly wheel in middleish with a weight in the back. there is a indeacator on the weight like a ruler. if rear could be differinal.
---------- Post added at 03:53 PM ---------- Previous post was at 03:51 PM ----------
its a fly wheel in middleish with a weight in the back(on engine). there is a indeacator on the weight like a ruler. if rear could be differinal. if you need a pic i can do that some time today.
SUCK MY DUST
Old 09-14-2011, 03:00 PM   #11
It feels like the rear end
Old 09-14-2011, 03:07 PM   #12
00STANG00's Avatar
does the engine shake
SUCK MY DUST
Old 09-14-2011, 04:09 PM   #13
Probably your rear gears how many miles?
Old 09-14-2011, 04:45 PM   #14
120,000
---------- Post added at 05:45 PM ---------- Previous post was at 05:44 PM ----------
The engine does shake but that's normal all motors shake
Old 09-14-2011, 04:50 PM   #15
00STANG00's Avatar
Originally Posted by Blackedout
120,000
i know that more than normal
SUCK MY DUST
Old 09-14-2011, 04:53 PM   #16
Lol I just had to mess with you. Don't be offended my friend. No it doesn't shake like loose motor mounts...
Old 09-14-2011, 05:01 PM   #17
00STANG00's Avatar
im not lol check rear gears or suspenion
SUCK MY DUST
Old 09-14-2011, 05:09 PM   #18
The rear suspension is lower than the front suspension. the gears are stock the suspension is stock.
---------- Post added at 06:04 PM ---------- Previous post was at 06:03 PM ----------
The gear fluid is stock..
---------- Post added at 06:04 PM ---------- Previous post was at 06:04 PM ----------
It's not that heavy. When I start the ca the car starts heavy
---------- Post added at 06:09 PM ---------- Previous post was at 06:04 PM ----------
I come home from work. Ok next morning turn on the car heavy shake and stutters to start. At park vibrates but not too heavy since I changed the o2 sensors. I had the code P1151. It vibrates it's noticeable
Old 09-14-2011, 10:55 PM   #19
00STANG00's Avatar
you needs shocks for sure
SUCK MY DUST
Old 09-15-2011, 02:12 PM   #20
hihosilver's Avatar
Send a message via MSN to hihosilver
This is the most confusing thread ever!
If it's something happening in park, I'm going to go ahead and assume the car isn't moving. (If not, you have bigger problems). If the car isn't moving, that rules out gears, wheels, driveshaft, rough roads, racoon in the wheel well, and probably the transmission. No part of the drivetrain aft of the transmission is moving!
Seems the most likely thing would be engine mounts, but if you're sure they're OK and the vibration is coming from the rear, it seems like it's got to be the exhaust vibrating against something. Does the vibration change with engine speed?
If the vibration doesn't change with engine speed, the only other thing I can think of that would make noise in the rear is maybe a fuel pump?
If it's not the exhaust or a fuel pump, it's probably an earthquake that only happens when you drive the car. So stop driving it before you hurt somebody!
hihosilver is offline   Reply With Quote
Old 09-15-2011, 02:16 PM   #21
I thought it was exhaust...
---------- Post added at 03:16 PM ---------- Previous post was at 03:16 PM ----------
But I was always worried about the rear end...
Old 09-15-2011, 02:23 PM   #22
00STANG00's Avatar
push down on rear if bounces a few times you need new shocks
SUCK MY DUST
Old 09-15-2011, 02:25 PM   #23
Alright
Old 09-15-2011, 02:35 PM   #24
Re: Heavy vibration in rear end
Like was stated, it can't be the rear end if you are, in fact, in park. Nothing moves back there when you're parked.
Rear end swap bmabbott Pre-2005 V6 Mustang 9 10-01-2011 12:14 AM
Rear end trouble Dgerow12 Pre-2005 V6 Mustang 15 09-08-2011 03:59 AM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 03:15 PM
Rear end BigSteve305 Pre-2005 V6 Mustang 5 08-15-2011 09:25 AM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 06:14 PM
07:19 PM
