whining noises? - Mustang Evolution
Old 09-14-2011, 11:30 AM   #1
96civic87's Avatar
whining noises?
Im hearing whining noises from under the hood. Im thinking maybe its tge power steering pump not sure. It does it when im at idle not moving but gets louder at acceleration and turning. I no my belt needs to be change but that would make it sound like tht idk. Maybe the bearings on a pulley? My power steering reservior is full so im think the pumps bad. Sry for the long read any help is greatly appreciated thanks in advance!
96civic87 is offline   Reply With Quote
Old 09-14-2011, 11:47 AM   #2
Bballing0416's Avatar
Its the power steering most likley.
Bballing0416 is offline   Reply With Quote
Old 09-14-2011, 12:39 PM   #3
DSGstang513's Avatar
Powersteering is noisy on all fords just gotta deal with it lol
DSGstang513 is offline   Reply With Quote
Old 09-14-2011, 12:57 PM   #4
96civic87's Avatar
No it wasnt bad before
Now its really loud like hear it from a block away loud lol
Old 09-14-2011, 12:58 PM   #5
Check your fluid
---------- Post added at 02:58 PM ---------- Previous post was at 02:58 PM ----------
Might have a ps leak
Old 09-14-2011, 09:16 PM   #6
96civic87's Avatar
Ps leak
Old 11-11-2011, 12:12 PM   #7
NYmustang5's Avatar
Re: whining noises?
Man I've been having the same problem for weeks. I changed the pump twice and nothing. I am frustrated man, ford sucks when it comes to power steering. I read someone put lukas powersteering leak protector in their fluid and it helped. (they did not have a leak) I will try this out and see wat happens. good luck
NYmustang5 is offline   Reply With Quote
Old 11-11-2011, 12:38 PM   #8
deadsp0t's Avatar
Make sure the P/S fluid is clean and full. If the problem persists change your belt. Belts cause all kinds of noises and can be bad even if it looks fine.
That's unimpressive
Old 11-12-2011, 10:13 AM   #9
shipwreck_98's Avatar
Re: whining noises?
There is a screen on the return line at the bottom of the pump that probably needs to be cleaned. Do a complete flush and while you do that clean that screen. That should help.
shipwreck_98 is offline   Reply With Quote
Old 11-13-2011, 11:23 AM   #10
waybad's Avatar
My 98 had the same problem. I replaced the power steering twice, and it wound up just bring one of the pulley's. You checked those?
waybad is offline   Reply With Quote
Old 11-14-2011, 09:48 PM   #11
Re: whining noises?
Idler pulley can be culprit.
A BG flush would be great.
I mentioned before that I changed my fluid till clean. Mobil1 auto trans fluid has worked great for years, quiet operation for a Ford.
Old 11-15-2011, 08:58 AM   #12
NYmustang5's Avatar
Re: whining noises?
have not checked the pulleys yet. I am getting a factory ps pump installed tomorrow, depending on how that goes, i will give the atf fluid a try and will also check the pulleys
Old 11-15-2011, 01:52 PM   #13
waybad's Avatar
Ok man, I wish you the best of luck!
06:10 PM
