Bad pcm?? - Mustang Evolution
Old 09-15-2011, 10:54 AM   #1
Dgerow12's Avatar
Bad pcm??
So I have a 2000 mustang v6 and I'm having obd troubles. Check light came on with a p1414 code. I checked wires and found out that two of the air pump wires had shorted/ broke. I bought a new pigtail and wired in but mixed up two wires code changed to p1413. I fixed the wire problem and code changed to a p0412. I checked fuses one was blown I replaced and code came back. A few days later I had my codes read again and is now throwing a p0153 and p0412 and my catalyst oxygen sensor and eve monitors are all coming up incomplete. What could be the problem?? Bad PCM Mabye? Any help would be really appreciated I got one month til inspections.
Dgerow12 is offline   Reply With Quote
Old 09-16-2011, 03:26 PM   #2
Dgerow12's Avatar
So checked out the code p0412 and it's air pump control valve faulty... And my o2 code went away... But I talked with a mechanic friend of mine and we agreed that if my cats are clogging then that would cause backpressure into the air system causing it to think it's a bad control valve and not enough exhaust reaching the o 2 sensor making it slow to respond. Think were on the right path here?? Help would be appreciated
Old 09-18-2011, 02:45 PM   #3
Ghostedmind's Avatar
Re: Bad pcm??
if the o2 sensors dont have enought to read that could cause the engine to be a bit slow... or at least have crappy gas mileage i think
96 SVT Cobra appears Superchip is bad opinions on my options please Spiney SVT Mustang 15 11-07-2011 07:34 AM
PCM & Tune ??? Devildog1679 2011-2014 Mustang GT 13 09-21-2011 04:40 AM
Nothing i hate worse than bad customer service dailey 2011-2014 Mustang GT 4 09-12-2011 03:25 PM
Bad MAF? MustangGT02 1996-2004 Mustang GT 22 08-28-2011 08:53 AM
Bad luck... Blackedout Pre-2005 V6 Mustang 20 07-29-2011 07:50 AM
10:32 AM
