1995 3.8 l v6 mustang wont start. Help Please - Mustang Evolution
Old 09-16-2011, 09:39 PM   #1
I just bought a 95 3.8 l mustang and it had been sitting for awhile so it need to be jumped to start it. Now when i turn the key nothing happens no lights, radio or anything just a clicking noise from the trunk. I just replaced the battery and still nothing. It wont jump start or even try to turn over. Battery cables seem fine. Terminals aren't corroded or anything. Any ideas?
zmckibbin is offline   Reply With Quote
Old 09-17-2011, 10:11 AM   #2
Ghostedmind's Avatar
Have you checked fuses, starter, relays, wiring harness....if its clicking the sounds like the starter or the solenoid. If its not doing anything at all then its electrical...somewhere from the battery to the ecu and the starting/charging system.
But im not a certified mechanic.....that's just things I've always been told
LCMC Member
Old 09-17-2011, 10:20 AM   #3
Re: 1995 3.8 l v6 mustang wont start. Help Please
Yeah ive checked all the fuses there all fine. The clicking isnt coming from the starter or anything and it continues to click for awhile even after you remove the key. How can i check the electrical stuff?
Old 09-17-2011, 12:40 PM   #4
Fallow the batter wires make sure there either grounded well or attached very well there can't be any wiggle room
16218 is offline   Reply With Quote
Old 09-17-2011, 07:47 PM   #5
If you have a multimeter it would help.....but it sounds like an ignition problem maybe....like maybe something shorting and creating a circuit and letting it continue to run......so in my opinion I think its a wiring issue
LCMC Member
Old 09-18-2011, 12:15 PM   #6
I found it thank you everyone. There was a broken ground wire going to the starter and i cleaned all the electrical connections, put it all back together and it started right up.
Old 09-18-2011, 02:08 PM   #7
Awesome...im glad you found it
LCMC Member
Old 09-19-2011, 12:29 AM   #8
Told you
v6 mustang
« Bad pcm?? | Pics »
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
01:29 AM
