springs? - Mustang Evolution
Old 09-20-2011, 07:27 PM   #1
austinknoll's Avatar
springs?
What springs would drop my stang the most? For how much money too?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-20-2011, 10:16 PM   #2
Titus Wadicus
svtlx's Avatar
Re: springs?
i bought sum cheap ones on ebay
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-20-2011, 10:23 PM   #3
Las0mbra's Avatar
Well, 2 questions.
1. What kind of springs are you looking for? Performance/racing type springs, or just lowering springs?
2. Kinda depends on what you want, but how much are you wanting to spend?
Because if you want performance, H&R makes supersport springs that will drop about 2" for $250ish, or you could get some cheaper from eBay or another store like that. And honestly, I wouldn't go lower than 2-2.25 inches, any lower than that and you're asking for a damaged k-member.
Old 09-20-2011, 10:57 PM   #4
I'm just going for looks
65 Mustang coupe
Old 09-20-2011, 11:00 PM   #5
Las0mbra's Avatar
For that, I'd spend about $150 on eBay springs, then buy some MM castercamber plates and a bumpsteer kit.
Old 09-20-2011, 11:40 PM   #6
03GT88's Avatar
The amount you drop determines if you need new cc plates
03GT88 is offline   Reply With Quote
Old 09-20-2011, 11:42 PM   #7
Las0mbra's Avatar
He's asking for a really low drop, hence my suggestion for cc plates and a bumpsteer kit. The cc plates are required after about a 1.5inch drop.
Old 09-20-2011, 11:46 PM   #8
I wanna go for a 2 inch drop. What's a bumpsteer kit?
65 Mustang coupe
Old 09-20-2011, 11:47 PM   #9
03GT88's Avatar
I'm aware hence I didn't know ebay spring specs
Old 09-20-2011, 11:55 PM   #10
Las0mbra's Avatar
I don't know exactly what one is or how you install it, but basically once you lower your car enough, every bump you hit affects your steering a lot, so it helps that.
Old 09-20-2011, 11:57 PM   #11
93slowstang's Avatar
I haven't had that problem, mines lowered 2.25". Maybe ive just been lucky though.
Old 09-21-2011, 01:32 AM   #12
deadsp0t's Avatar
Cheapest, easiest lowering. People I know/known take 87-93 springs and cut a coil out of them. I believe they say to use springs from a 4cyl car, because they are designed for a lighter load? I'm also to told they transfer weight well. I've seen this done to several cars, most of which 4cyl-8cyl swaps that were not street cars. Most but not all.
---------- Post added at 01:32 AM ---------- Previous post was at 01:31 AM ----------
Side note: My springs say CJ Pony on them, and both my other cars rode on the same Steeda springs.
That's unimpressive
Old 09-21-2011, 06:02 AM   #13
Titus Wadicus
svtlx's Avatar
Re: springs?
My 2" drop springs were $78 shipped. I drilled out the rivets on the stock camber plate and moved them all the way towards the outer fenders. I would describe them not overly stiff specific rate springs
Old 09-21-2011, 08:04 AM   #14
kickerofdoom's Avatar
I love my Ford racing b spring except that I hit the ground sometimes
Old 09-21-2011, 09:10 AM   #15
I'm probably going to get them installed by a mechanic because i don't have the tools for it.
65 Mustang coupe
Old 09-21-2011, 09:13 AM   #16
Re: springs?
As mentioned, the V6 is about 100lbs lighter up front. Do a bunch of research if you want it to look right and handle correctly.
I went with Fox Body springs & shocks/struts. Got more than 2" drop. Very smooth ride. I also got the X-2 ball joints to get additional 1/2" drop up front so it's even all the way around.
Old 09-21-2011, 10:30 AM   #17
Re: springs?
springs will run 200-250 for a good set, drop is up to you they dont cost more genearlly for more of a drop.
For a daily drive i would NOT go lower than 1.75 inches, 1.5 seems to be the sweet spot.
you will need c/c plates (180 bucks)
install is EASY you can do it yourself (read my article on here about how to install springs)
or you can pay a shop 200-400 to install/align it
Old 09-21-2011, 10:48 AM   #18
deadsp0t's Avatar
+1
don't forget that trip to the alignment shop
That's unimpressive
Old 09-22-2011, 01:36 AM   #19
Re: springs?
+1~ I went with Ford Racing "B" springs also. Not the most popular choice but very nice parts. H&R, Eibach, B&G, BBK, Sprint, are some of many more popular springs. Alot of these companies make V6 specific springs now a days.
Ford Racing "B" Springs on my car:
Old 09-22-2011, 09:14 AM   #20
deadsp0t's Avatar
Wow looks great to me!
That's unimpressive
Old 09-22-2011, 08:17 PM   #21
Agreed!
65 Mustang coupe
Old 09-22-2011, 09:19 PM   #22
davidr_1961's Avatar
Re: springs?
You DO NOT need to spend money on Camber plates, Elongate the top strut mounting hole in the strut and wala, you can get as much as 1 degree camber without spending a dime, this usually is more than enough and won't change your SAI enough to matter., or screw with your ball joint to much, and if you're doing an install on the strut its a perfect time to do it. Lowering very rarely changes caster. "Bump Steer" is an effect not a thing and it can come from worn parts or to much angle on your steering linkange, wich comes from lowering your car too much or not lowering it correctly. Yeah you can install these so called "bumpsteer kits" they will correct the angle but add componets to your steering linkage and dramitcally increase the probability of failure.
theres a reason Eibach and other GOOD manufactures recommend 1.1" 1.2" 1.5" inch spring kits, thats the max the geometry of your car can handle BEFORE you **** off the rest of your suspension because you went to low, beyond the limits.
Be careful of cheap fixes, they usually cost you way more in the long run than if you did it right the first time, ever hear the term "Mickey Moused"? We have a saying around my shop, "good parts don't come cheap and cheap parts don't come good"
davidr_1961 is offline   Reply With Quote
Old 09-22-2011, 09:46 PM   #23
deadsp0t's Avatar
With respect I'd much rather buy C/C plates then "walla" out the holes to
Achieve desired adjustability. Then again someone already put the C/C plates on mine.. 
---------- Post added at 09:46 PM ---------- Previous post was at 09:45 PM ----------
"wallaing" out doesn't count as a cheap fix, or Mickey Mouse as you say? Just asking?
That's unimpressive
Old 09-22-2011, 10:25 PM   #24
Re: springs?
Really? do you have a point to make with your question, Elongating has been an accepted modification technique by the automotive industry far much longer than camber kits, I've personally been doing it for over 22 years and my journeymen have over 25 years each, Whaddaya think. do we have ears on?
Old 09-23-2011, 01:11 PM   #25
Titus Wadicus
svtlx's Avatar
Re: springs?
some of us here are more mechanicaly inclined than others. i agree with modifying the holes. but i just moved the stock plates over till they run outa adj. i believe c.c. plates are for those that are less comfortable drilling & cutting holes into their mustang. at the end of the day we all end up with the same results, but some of us are able to keep 200-300 dollars in our pocket at the end of that day.
example.... a torque link from jegs cost $60. i bought a similar tie down from lowe's for $8. it does the same thing and goes in the same location. best of all it was actualy easier to install than the jeg's torque link.
that doesnt make my car mickey moused.... like the c.c. plates, sum of us know how to work around it and get the same results.
Old 09-23-2011, 01:49 PM   #26
Wow, no one said that camber plates or tie's was mickey moused, if ya'll had read the thread you woulda picked up on cutting springs and installing springs from other models and the such. Or did that blow right over your head? Apparantly so, i'm not the enemy guys, i was just sharing my experiance and opinion, please dont take either one of them personally.
Old 09-23-2011, 02:00 PM   #27
Titus Wadicus
svtlx's Avatar
Re: springs?
lmao.... i guesse i shoulda "plus 1'd" that. i called myself bakn u p on that. my bad. thats not how i meant that at all.
and for the record. i dont condone cutting springs or torch'n them...lol.
i was just tryn to make a point too
Old 09-23-2011, 02:35 PM   #28
deadsp0t's Avatar
Was just asking man. Bought my car a month ago, the CJ Pony springs and maximum motorsports C/C plates. Neither of my two previous cars were lowered or had plates. I would have no issue cutting springs or drilling the holes. Sorry didn't mean to be a d*ck bro. Just observing irony lol
That's unimpressive
Old 09-23-2011, 02:45 PM   #29
Lol, its cool, i get caught up using shop language all the and my intent was not to offend anyone, its just that i see the aftermath of it all the time and really hate to see it when it can be avoided.
Lowering springs 89white GT 1979-1995 Mustang GT 13 08-31-2011 09:32 AM
Lowering springs 89white GT AmericanMuscle 1 08-30-2011 04:11 PM
Ebach springs.. Brandon91 1979-1995 Mustang GT 3 08-05-2011 06:38 PM
Lowering springs. GoldenPonyBoy 2005-2010 V6 Mustang 13 07-26-2011 06:40 PM
Lowering springs for 2007 Redmustang2007 2005-2010 V6 Mustang 10 07-14-2011 03:28 PM
10:49 AM
