05-11 rims on 99-04 - Mustang Evolution
Old 09-20-2011, 10:12 PM   #1
austinknoll's Avatar
05-11 rims on 99-04
Anybody got any pictures? I'm looking for rims for my 2000 and can't find any pics
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-20-2011, 10:17 PM   #2
Titus Wadicus
svtlx's Avatar
Re: 05-11 rims on 99-04
i believe you have to get spacers for those to fit correctly
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 09-20-2011, 10:24 PM   #3
Las0mbra's Avatar
+1, you need about 1" to fit properly
Old 09-20-2011, 11:47 PM   #4
Oh damn well I guess I'm goin with the 17in gt wheels
65 Mustang coupe
Old 09-21-2011, 06:51 AM   #5
96civic87's Avatar
I hve 05 wheels with out any spacers
96civic87 is offline   Reply With Quote
Old 09-21-2011, 09:22 AM   #6
They are making them without the need for spacers. EFImustangparts.com has a bunch to choose from. Not cheap. Very cool looking.
Old 09-21-2011, 10:29 AM   #7
they work but spacers are needed to maintain the stock setup, tight turns may rub the sway bar or a arm etc (tie rod)
Old 09-22-2011, 12:46 AM   #8
More available lately without spacers needed. Offset & dimensions set up for 94-04 Mustangs. mustangsunlimited, brothersperformance, americanmuscle, cruizenconcepts("S" style is beautiful), ect.. Some really beautiful wheels to make your car stand out from the crowd!
Favorite stock rims? NV Laser Red Mustang Wheels & Tires 39 11-04-2011 05:25 AM
put gt500 rims on my 2011 gt guzie 2011-2014 Mustang GT 13 09-02-2011 04:38 PM
Rims are gone :( Otlaw80 General Car Discussion 4 08-31-2011 10:28 AM
2005 rims on an 2002?? Stang02seth Mustang Wheels & Tires 6 08-12-2011 11:33 PM
Powder coat wheels/ buy new rims STONE47 General Car Discussion 8 08-02-2011 12:55 AM
09:06 PM
