V6 Mustang Brake Booster Problems - Mustang Evolution
Old 10-01-2007, 02:39 PM   #1
Since getting the car back from having the new engine put it there is a problem with the brakes. It seems like they are not getting enough pressure built up while in areas like parking lots or when first starting the car up and backing up and driving. The brakes do not stop well at all. You can feel the pads hit the rotors when you press the brakes but the car doesn't stop well.
However when driving down the rode this seems to go away.
What would cause this? I took it to a mechanic and they could not single out the problem but hinted at the Brake Booster going bad. Has anyone had experience with something like this before?
Old 10-01-2007, 02:41 PM   #2
rydog's Avatar
Send a message via MSN to rydog
Re: 1996 V6 Mustang Brake Pressure Problems
its the cam you have, bleeding off pressure less pressure the brake booster
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 10-01-2007, 02:46 PM   #3
Seriously? Is there any way to fix it? It's pretty bad when first starting up.
Old 10-01-2007, 02:48 PM   #4
rydog's Avatar
I dont know of a way I just dealt with in my 82:dunno:
what is your vacum at idle?
Old 10-01-2007, 03:11 PM   #5
I found this and it looks like a good solution: Brake Boost
This is probably why the transmission seems to lag a bit when first accelerating from a stop since it requires vacuum as well. :chin:
Old 10-01-2007, 03:14 PM   #6
rydog's Avatar
That's the ticket
Old 10-01-2007, 03:22 PM   #7
and here is more reading on it from someone who has done it: Hydro-boost (brakes) - V6Power Messageboard
Old 10-01-2007, 03:29 PM   #8
Another possible solution: Stainless Steel Brakes Electric Vacuum Pump Kits: SSB-28146 - summitracing.com
Old 10-01-2007, 03:31 PM   #9
rydog's Avatar
That ones a bit pricey though I like the GT fix better
Old 10-01-2007, 03:32 PM   #10
Problem is buying all those parts form the Junkyard probably won't be cheap either... then you gotta cuss up a storm taking the whole brake system apart lol...
I got to look into if this would fix the Transmission problem as well.
Old 10-01-2007, 03:40 PM   #11
My v6 had that problem too. I think it was the booster but like you said no one could diagnose it. I would just let the car run for about 30 seconds when I started it up if I wanted to avoid the problem all together or I'd just be ready for it the first 30 seconds of drving.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 10-01-2007, 03:40 PM   #12
What kind of cam did you run?
Old 10-01-2007, 04:30 PM   #13
mine was stock!
-Denver
Old 10-01-2007, 05:11 PM   #14
Yea then your booster was probably gone then....
Old 10-01-2007, 05:27 PM   #15
Send a message via AIM to white95v6
oh man. slow down.
whats your cam? cause i have run Large cams and no issue yet with no haveing enough vacum on the boost for decent stoping. also just buy a $40 Vacum canister. no need for those things you posted about.
also the Trans does not use anything from a Vacum source to run or funstion properly.
if the cam is decent a Stall and a Gear will wake it up Alot.
this is nothing new why are you guessing at a fix?
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 10-01-2007, 05:34 PM   #16
because its bad enough to where it needs to be fixed and I have never encountered it before. This is my first build period.
It's bad enough at idle where I would like to fix it. I'll look into the Vacuum Canister. I guess the Transmission problem is with the tune then.
Thanks.
Old 10-01-2007, 05:38 PM   #17
Thanks.
i didn't say it was not enough of a problem that you should not fix the issue.
again i say what Cam do you have? this will shine some light as to if its your problem or not.
the trans could be a tune,converter or just wore out lol
Sponsored by:
Old 10-01-2007, 05:39 PM   #18
Sorry forgot that. Its 224/230. I gotta find the spec sheet for the lift specs.
Old 10-01-2007, 05:40 PM   #19
Well I say its probably the tune because the tranny shifted fine before the build and now it seems sluggish.
Old 10-01-2007, 05:45 PM   #20
Thanks.
need the Lobe sep and IC.
Sponsored by:
Old 10-03-2007, 10:45 PM   #21
Re: V6 Mustang Brake Booster Problems
Found the sheet:
Old 10-04-2007, 02:37 PM   #22
Found the sheet:
hmm with that cam it should not have any issues building vacum to stop the car.
whats your vacum at idle?
no vacum leaks right?
Sponsored by:
Old 10-04-2007, 07:29 PM   #23
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Sounds more to me like a vac leak. It's possible that when the engine was put in your booster line might not have sealed properly or been kinked possibly?
DarkShadow is offline   Reply With Quote
Old 11-05-2007, 05:08 PM   #24
Send a message via AIM to AlexJ
My stock v6 does this same thing. And it is stock. I've just kinda ignored it up until now...
AlexJ is offline   Reply With Quote
Old 11-05-2007, 08:38 PM   #25
rydog's Avatar
^well somethings wrong for sure and dont ignore it now
v6 mustang
99 35th. ann. GT brake problems !! HELP!! plz j4gwig 1996-2004 Mustang GT 6 06-22-2010 05:28 PM
Brake problems 67mustang97 1996-2004 Mustang GT 4 04-06-2010 06:39 PM
Brake Problems LSUstang Pre-2005 V6 Mustang 9 06-20-2009 05:21 PM
Brake Problems on a 71 Mach 1 71 Mach 1 Classic Mustangs 6 04-18-2009 06:54 PM
Vacuum booster Black Panther Pre-2005 V6 Mustang 2 02-12-2007 09:45 PM
11:50 AM
