2004 v6 idles question - Mustang Evolution
Old 09-26-2011, 02:45 PM   #1
96civic87's Avatar
My 04 v6 rpms stick for a lil while inbetween shifts. Its like they dont drop off fast enough. When i stop ot stays reved up about 5-7 seconds after i stop any ideas or info would be great
96civic87 is offline   Reply With Quote
Old 09-26-2011, 04:05 PM   #2
BlackGT's Avatar
Re: 2004 v6 idles question
That's pretty odd. But the only thing that comes to mind is your IAC Valve. Idle air control. They sometimes stick. Ever have any troubles with low idle or even sometimes stalling? IAC's generally cause low idle tho not high idle problems.
---------- Post added at 06:05 PM ---------- Previous post was at 05:53 PM ----------
Also be sure your throttle plate is not sticking and you have no vacuum leaks. Do you have a check engine light? What rpm are you stuck at?
BlackGT is offline   Reply With Quote
Old 09-26-2011, 07:32 PM   #3
96civic87's Avatar
Ok so i cleaned my iac valve and its running alot better rpms droppin likethey suppose to as soon as i cluth it. Runs alot smother during shift and droos to about 6-700 at idle sounds good to me idk. I did notice tht my throtle body cable is kinda loose where its spooled up at is that normal or should it be tight?
Old 09-26-2011, 07:44 PM   #4
austinknoll's Avatar
You should seafoam your car. When I did mine, it ran like new
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-26-2011, 07:51 PM   #5
BlackGT's Avatar
Throttle spring shouldn't be an issue as long as the throttle snaps back to the full closed position (should hit the stopper or adjustment screw which you should never touch)
---------- Post added at 09:51 PM ---------- Previous post was at 09:47 PM ----------
Seafoam is never a bad idea. Ive heard alot of good things. Works wonders cleans your injectors and your intake valves
Old 09-26-2011, 08:19 PM   #6
96civic87's Avatar
Seafoam? Put one container in a full tank of gas? Where do i get this like auto zone?
Old 09-26-2011, 08:30 PM   #7
Ghostedmind's Avatar
Anywhere....but its definitely cheaper right now that normal....I don't know if all stores are doing the sale but I found it at advance auto for 3 dollars off (normal price is like 9.99)
And yes one can in a full tank
LCMC Member
Old 09-26-2011, 08:33 PM   #8
96civic87's Avatar
Thanks ill check it out at lunch tom
Old 09-26-2011, 08:35 PM   #9
No prob
LCMC Member
Old 09-26-2011, 08:48 PM   #10
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
i need to seafoam also
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-26-2011, 09:20 PM   #11
I put half in my brake booster vaccuum line and half in my gas tank. Cleaned intake valves and fuel injectors
65 Mustang coupe
Old 09-26-2011, 09:45 PM   #12
Your exhaust manifold is leaking hense why you prolly hear almost like a clicking sound in a way when your car is running..
Freshtang is offline   Reply With Quote
Old 09-27-2011, 07:44 AM   #13
clean the MAF sensor, may help mine used to do the same thing after it got gunked up
Old 09-27-2011, 11:33 AM   #14
96civic87's Avatar
Will try it
Old 10-05-2011, 11:14 AM   #15
Herbstang's Avatar
All good info !!!! But your RPM decay rate can be the cause, mine did the same thing had it adjusted using SCT chip It's an annoying trait, programmed into the PCM to burn off excess fuel
2004 3.9 V6 pipes 96civic87 Pre-2005 V6 Mustang 16 09-13-2011 04:47 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 12:29 AM
03 v6 stock system question TaylorF25 Mustang Audio & Video 2 07-19-2011 11:32 AM
10:54 AM
