auto shifter cable to steering wheel. - Mustang Evolution
Old 10-01-2011, 12:44 AM   #1
alright I'm getting ready to turn my 00 into a 3.8 automatic ( sadlly ) but 200k on a trans and motor.... vs 60k trans + motor - 60k won.
The question I have at the moment... an automatic shifter has the linkage cable that goes to the back of the steering colum to lock it.. well would I be able to get away with putting the auto shifter in and not connecting the line to the back? what if any issues would this cause?
Black_Sunshine is offline   Reply With Quote
Old 10-01-2011, 08:10 AM   #2
Titus Wadicus
svtlx's Avatar
Re: auto shifter cable to steering wheel.
Nothing goes to the steering column. Sooo I'm having sum difficulty understanding wut ur askn
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-01-2011, 11:24 PM   #3
there is a cable that goes from the auto shifter to the back of the steering wheel ( to lock the shifter ? )
Old 10-02-2011, 05:51 AM   #4
stangkid's Avatar
stangkid is offline   Reply With Quote
Old 10-02-2011, 06:54 AM   #5
ForsakenProto's Avatar
You're referring to the tiny switch located behind the key on your steering column right? It's my understanding that if you're going to an automatic then you have no need to put anything there as that switch is sort of a lock if sorts that autos don't have since they just slip into park and don't have to worry about rolling in most cases
ForsakenProto is offline   Reply With Quote
Steering wheel emblem nickdandria General Car Discussion 3 08-03-2011 08:43 AM
Steering wheel removal zrider07 1996-2004 Mustang GT 3 07-25-2011 08:54 AM
06:28 PM
